brick tablet china
brick tablet china
31
2014/06/19 - 15:20
Hm, what fimware do you use? The one from the russian forum? Or did ZED send you something?
twingo16s
Forum Posts: 48
32
2014/06/19 - 15:40
if you send him to zed. unresponsive. no wonder they can flash rom from another brand? Or you cosinadas?
33
2014/06/19 - 15:57
I do not really understand where you are. Maybe it is better you write in your language and I will use a translator.
twingo16s
Forum Posts: 48
34
2014/06/19 - 16:02
JAJAJA castellano español ,   si ya le mande a zed .no responden . pregunto no se se pueden flashear rom de otra marca ? , o rom cosinadas ?
35
2014/06/19 - 16:14
Ok, here is kernel 3.0.8+ lsd@zed-server3 # 3 preempt 06.11.2012.
It is from the build (aijian_RK3066_ZM973_T020509E_S02_C0A_A02_20121106) found in the russian forum.
You can try our CM10.1 build: http://crewrktablets.arctablet.com/?p=1913
Replace the kernel in folder rockdev/Images and flash incl. eraseIDB.
twingo16s
Forum Posts: 48
36
2014/06/19 - 16:22
OMA eres muy amable . perdon no se como hacerlo . no entiendo que es lo que hay que bajar y como flashear
twingo16s
Forum Posts: 48
37
2014/06/24 - 04:05
HOLA OMA . logre flashear CM10 .funcionaba mal la camara . volví a flashear la original y funcionaba mal . flashe otra vez CM10  el thouch no funciona bien ,que puede ser ? se pudo haber estropeado de tanto flashear rom
twingo16s
Forum Posts: 48
38
2014/06/26 - 16:54
hello OMA. everything works fine with mouse, not work tatil screen,
what would be the problem?
hola OMA . funciona todo bien con mouse , no funciona el tatil de la pantalla ,
cual seria el problema ?
39
2014/06/26 - 17:46
Here is a model fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1881
twingo16s
Forum Posts: 48
40
2014/06/27 - 04:26
installed as well? , What I did is copied to external sd into recovery and flash
se instala así ? , lo que hice es copiar en sd externa entrar en recovery y flashear
41
2014/06/27 - 07:23
Yes, boot into CWM and install from external sdcard.
twingo16s
Forum Posts: 48
42
2014/06/27 - 14:14
not work as usual, the touch stopped working when flashee wrong ROM,
I think I'll leave tired tablet,
thank you very much greetings OMA
twingo16s
Forum Posts: 48
43
2014/07/02 - 20:08
oma , cm10 funciona perfecto si uso mouse el tatil no funciona
cm10 works perfect if I use mouse, tatil not work
44
2014/07/02 - 20:11
Did you install the model fix?
twingo16s
Forum Posts: 48
45
2014/07/02 - 20:41
si lo instale como tu me dijiste , lo
if you install it as you told me
89 Guest(s)
Devices in use: Desktop (77), Phone (12)
swan12
heftpflaster
