brick tablet china
brick tablet china
twingo16s
Forum Posts: 48
2014/06/10 - 21:52
screen does not turn on. not work keys
2014/06/10 - 22:25
Sorry, you lost me if you mentioned Antutu give you something ...
twingo16s
Forum Posts: 48
2014/06/10 - 22:33
when you buy before brik
twingo16s
Forum Posts: 48
2014/06/10 - 22:36
Ahora this,, esto, la pantalla no se enciende. no trabajar teclasNow this, screen does not turn on. not work keys
twingo16s
Forum Posts: 48
2014/06/10 - 22:39
lo siento Estoy Complicado Con idioma
2014/06/10 - 22:43
No problem. We will continue tomorrow. Buenas noches.
twingo16s
Forum Posts: 48
2014/06/10 - 22:45
goodnight thanks
2014/06/11 - 20:18
Ok, this is a: Zed ZM973, RK3066 2x1.6Ghz, Android 4.1, 16GB, microSD. Mali 400, 9,7", 1024*768, IPS, 1Gb DDR-III
There is also a ZM973 fx with a higher screen resolution.
No screen means the kernel wont fit for that tab.
Keep on searching http://4pda.ru for firmware images and flash it until you have a working screen. If you have a working screen but no touch, use an usb mouse.
Good luck!
twingo16s
Forum Posts: 48
2014/06/11 - 20:36
FX ZM973 ??
2014/06/11 - 20:49
http://www.zediel.com/Products/View.asp?id=52
FX is the one with the higher resolution.
twingo16s
Forum Posts: 48
2014/06/11 - 21:22
thanks, send email to ZED, let's see if you send
twingo16s
Forum Posts: 48
2014/06/18 - 18:27
 THANKS OMA. solved   Problem solved, download PdaNet. and rk in flashe reconcio the green rom and it works
works a little better. the problem still showing full battery
2014/06/18 - 18:51
Great news!
So what tab is it now and where to find the firmware?
twingo16s
Forum Posts: 48
2014/06/18 - 19:37
Great news!
firmware you step, but does not work well restarts and many problems do root and do wipe datas?
twingo16s
Forum Posts: 48
2014/06/19 - 15:15
twingo16s said
Great news!
defective work, freezes often, you can flash another ROM from another brand?
93 Guest(s)
Devices in use: Desktop (82), Phone (11)
swan12
heftpflaster
