2014/04/15
Hola tengo el PC de la tableta en el ladrillo despuĂ©s de juego flash rom terminĂł varios ladrillos. Proseso hizo corto circuito y reconociĂł las PC, las luces de la herramienta lote Rockchip azules.Â
ahora no puede encontrar rom para esta tablet, no estaba la escalera. si me pueden ayudar por favor: BANG: WTF
http://es.focalprice.com/CE0192X/V92...uch_16GB_.html
ajustes de la tableta de escritura
RK30 SDK TABLET PC vercion DEL KERMEL 3.0.8 + ISD @ ZED-SERVER 3 # 46Â
RK 30 ANDROID 4.1.1 SDK V1.00.00Â
RV1FU-V2.60 .............
si usted necesita la otra escritura de datos y me dices gracias
Just googled for ZM973_v1.1: http://4pda.ru/forum/lofiversion/index.php?t445527.html
At the end is a working firmware link.
2014/04/15
Just googled for ZM973_v1.1: http://4pda.ru/forum/lofiversion/index.php?t445527.htmlAt the end is a working firmware link.
thank you very much, OMA will gift if it works for you,
2014/04/15
does not load the ROM the same red sign IDB failure
Use RKBatchtool v1.5: http://crewrktablets.arctablet.com/?wpfb_dl=1518
Start tab in mask-rom modus: http://www.arctablet.com/blog/forum/archos-arnova-general/problem-with-rk3188-tabletu35gt2/#p42924
2014/04/15
Part 2: Erase corrupt NAND memory
1. Click on the #1 box within RKAndroidTool (the Loader box)
2. Click on "EraseIDB"
3. Wait for the RKAndroidTool to indicate the EraseIDB was successful
4. You can now close out RKAndroidTool
Part 3: Reflash firmware/ROM onto v88
1. Load firmware/ROM into RKBatchTool
2. RKBatchTool should have it's #1 Box highlighted in blue
3. Click Flash ROM
4. Done
this is what I do and it does not work
Did you start the tab in mask-rom modus (RKAndroidTool shows that) by shorting the pins?
??? you have a booting firmware?
70 Guest(s)
Devices in use: Desktop (60), Phone (10)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
