Wallpaper resolution
BoB77
Forum Posts: 28
2014/07/30 - 09:01
I found nice stuff for Retina with 2048x2048 resolution
http://fiftyfootshadows.net/2012/03/19/retina-ipad/
Is it any possibility to use them without cropping?
Thanks Received: 3170
2014/07/30 - 09:23
The "Retina" like resolution for the V972 and other models is 2048x1536, so it's not square and the wallpapers you are referring to will need to be adapted, either cropped or resized (with black bars added on the vertical axis). You'll find apps to take care of that on Google Play Store.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/07/30 - 15:14
BoB77 said
You can try this app that doesnt seem to crop the pictures , it should display the pictures as wall paper "as is".
72 Guest(s)
Devices in use: Desktop (58), Phone (13), Tablet (1)
tgergely2012
avv2011
leadpan101
jumbo65
kalkpits
m12k
