2013/08/17
http://pan.baidu.com/s/1mgjYyE0
Onda Tablet PC ROOT privileges crack
1 decompression generate two files in the following figure
2 decompression after the installation wizard brush on your laptop or desktop computer
3 After the installation is complete, use the USB cable to connect the tablet computer, and open storage mode
4 Copy the downloaded file to the panel, and then close the storage mode
5 Turn on the computer wizard Brush - Elect the utility
6 Click on plates set - Developer options - check the USB debugging
7 Click Brush Wizard (Get ROOT privileges)
8 start to get permission
After 9.ROOT complete, open Explorer plates
10 Installation Manager then open RE RE Manager (test whether ROOT success)
11.ROOT completed
Might be usable with other tablets as well.
The following users say thank you to iceqube for this useful post:
Jobster, badboy1deOnda V813
2014/02/05
I rooted my V975M and it worked until I power down and restart it then it is derooted for some reason. Just for the heck of it, to get rid of the bloatware, I tried something else and it worked. I d/l the 1.0.5 v1 firmware onto an SD card in my PC then opened up the files and deleted all the .apk files I did not want to install. Put the SD into tablet hold down volume+ for 4seconds then hold down power and keep holding both until green android appears, it updated and runs fine with no bloatware.
The following users say thank you to fid_def for this useful post:
I am waiting for the delivery of my ONDA V975m pad also (it is rather dissapointing to me to have a pad anything below 10.1inch screen size) but the lure of 32000++ Antutut score has brought me to buy this pad since it is also cheap in Asia. I dunno whether the supplier installed the stock 4.3 or the updated 4.4 OS yet until it is here. The rooting method is only good for A31 but this beast M80 AMLogic is another I would like to try VROOT to root it since I used the VROOT to successfully root my LENOVO A880 phablet where NO,NO NO others methods succeeds in one click it took it less than 20secs to achieve root on my A880. Since you already have your V975m and if you are interested I have attached it here the latest version can Root the NOKIA X phone. but it installs its own Superuser (blue icon) and has inbuild root uninstaller.Installs on your PC and get to its website links for te latest updated version.
About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/07/23
The download link from the 1st post is screwed. I have no idea where to get these files to root my tablet with 4.4.
I tried some other procedures from different aliens but ended it up with a screwed tablet. I've had to install the f/w like 3 times. I am talking about a V973-V2 but for what matters, it should be applicable to all tablets with the same processor but with 4.4 f/w.
Anyone?
I dont know whether this can help you with rooting (what model is that?) I have the rooting software for V975 V13 for Android 4.3 but I couldnt get anything else so far for the V975m KitKat Beta 3(4.4)
It doesnt install busybox so be careful , I have screwed up my other Android when the Chinese supplied out of the box with SuperSU installed (LENOVO brand) but cant update the SuperSU and cant install busybox, when I forced install it thats when the "insufficient memory available" msgs keeps cropping up and it doesnt symlink the busybox.
You can try to change the Superuser app in the folder with the latest SuperSU v1.94 + updated binaries (just change the spelling to "Superuser" since the META file(in the zip folder) refers to it as Superuser but it doesnt install busybox.
2013/07/23
I am tired of seeing so many Chinese letters or whatever they are!Â
Does anyone with any English knows how to root Onda for 4.4???
Or should I go an learn the damn language?Â
How stupid is for Onda to sell this product worldwide and release the s/w only in their damn language???
Only that, I should have think twice before buying the damned product!
You said it! Even a giant company like LENOVO have most of its Official firmware full of Chinese only apps. I dont know the language either but I live and gre up with them since the day I was born (multiracial country).And most of solutions are found only on China (chinese written) sites. Like rooting solutions and some of them are good at it.!Some are just out to destry your device.
I would suggest you try this site : http://www.v975m.com/forum/forums/15-Tablet-Onda-v972-Forum
Have you tried VROOT method yet?
2013/07/23
cracktech said
I dont know whether this can help you with rooting (what model is that?) I have the rooting software for V975 V13 for Android 4.3 but I couldnt get anything else so far for the V975m KitKat Beta 3(4.4)It doesnt install busybox so be careful , I have screwed up my other Android when the Chinese supplied out of the box with SuperSU installed (LENOVO brand) but cant update the SuperSU and cant install busybox, when I forced install it thats when the "insufficient memory available" msgs keeps cropping up and it doesnt symlink the busybox.
I have tried your file, it doesn't work. When using it on Android v4.4 it seems to be different, no root.
I have a Onda Tavlet V973 V2 and trying to upgrade to 4.4. It is hell!
I probably found a solution for you on A31 ONDA tablet -ROOTING method, I went back to my previous forum and found this "Root From OTA" :this is for A31 devices.
And the accompanying comments by the poster of the thread.
ADDENDUM : If you dont see Superuser app as being installed but have root access try to install SuperSU.
On this forums they have some negative comments on KASTY ROM, they say it is laggy compared to stock but rooted firmware.
iceqube said
http://pan.baidu.com/s/1mgjYyE0Â
11.ROOT completedMight be usable with other tablets as well.
Dont understand your explaination, please use proper English. I will soon have V975m tablet so the rooting method is important but I dont want to use Chinese Superuser for long (but if no other choice I had used it for about 2 months before there are advantages like build in root uninstaller and cleaner - VROOT).
The Chinese Superuser doesnt allow the installation of proper busybox , it did screw up my firmware. and your links dont work to download.
Yup was there before!
70 Guest(s)
Devices in use: Desktop (58), Phone (12)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
