[ROOT][TWRP RECOVERY] Onda V972 | Allwinner A31
ankar84
Forum Posts: 13
Thanks Received: 28
2013/04/04 - 05:40
TWRP based on lastest 2.4.4.0 for Onda V972 by ankar84
Download: in that post in attachments
Differences between TWRP and CWM Recovery
  • Graphical user interface with full touch control.
  • Batch patches (up to 10p in the queue).
  • Customizable backup/restore. You can choose which partitions to backup/restore if you want to use compression and generate md5-sum set their own names backup and delete unwanted right from recovery
  • Displays the time (time zone adjusted separately), battery.
  • Saving settings of the recovery on microSD-card.
  • Built in Terminal Emulator.
  • The ability to connect the two cards to the computer as a USB-carriers.
  • Built-in file manager, with copy, move, delete, rename, change permissions.
  • A detailed log file.
  • Theming support.
TWRP based on latest stable version 2.4.4.0
Internal and External memory are mounted properly.
Internal memory installed in the /sdcard
External Memory installed in the /external_sd
You can store backups on a Internal and External memory as well.
External card is automatically mounted
Team Win Project site
Compile manual
Thread on XDA
The following users say thank you to ankar84 for this useful post:
aryanitinkumar, admin, jored1222, lccifong, vlad-127, Philosopheur, Balrog, moisedanieln
2013/04/16 - 13:57
Thanks ankar84 for building this recovery.
It is now available in an ArcTools package for easy installation.
http://www.arctablet.com/blog/forum/arctools-application/installing-cwm-recovery-on-onda-v972-v812-allwinner-a31-tablets-with-arctools-root-required/
ankar84
Forum Posts: 13
Thanks Received: 28
2013/04/17 - 08:38
TWRP 2.5.0.0 for Onda V972
What's new in 2.5.0.0:
Special Note: If you are running a custom theme, the changes in 2.5.0.0 will likely not be compatible with your theme.
Added scrollable partition lists for mount, backup, restore, wipe, and storage selection
Add new SliderValue GUI element for selecting brightness and screen timeout (thanks to Tassadar)
Re-work AOSP and TWRP code to improve license compatibility between GPL and Apache
Added official theme for 1080x1920 portrait devices (HTC DNA, HTC Butterfly, Oppo Find 5, Sony Xperia Z, etc)
Fixed a problem with directory permissions on split archive backups
Fixed a problem with md5 verification of backups
Added a search function to libtar (thanks to kokotas)
Improve handling of XML errors (fix permissions)
Fixed handling of subpartitions
Improvements to recovery.fstab flags
Fixed a problem with decryption not being able to locate the decryption key in some situations
admin, Donkman, vlad-127, Philosopheur, Balrog, lee99
Philosopheur
Forum Posts: 16
2013/05/24 - 00:03
my device is an ONDA V972-v2 (ROM KASTY 4.2.2 v30 2013-05-22)
  • I can't install with Arctools neither TWRP 2.5.0.0 or CW-R (first line of the package)
Do have any idea about the problem ?
Tablette ONDA V972-v2 ROM STOCK 422 Root
Balrog
Forum Posts: 48
Thanks Received: 15
2013/05/24 - 01:19
Thanks for the TWRP 2.5.0.0!
It installs and run very fine on the V973 with the new Firmware 3.0 (Android 4.2.2).  :-)
I am able to make a full backup to the internal sd.
A backup to the external sd ends with the error: "E:Unable to create folder: /external_sd/TWRP (errno=1)".
The access of the external sd via the built in file manager is okay.
The following users say thank you to Balrog for this useful post:
elidoe89
2013/05/24 - 17:16
touch isnt working the 2nd time I access twrp , it started fine first time.
Balrog
Forum Posts: 48
Thanks Received: 15
2013/05/25 - 01:03
The TWRP 2.5.0.0 flashes and run good on the first custom rom 3.0 for the V973 V1.
Backup to internal sd is fine.
Backup to external again not but with a different error: "E:Unable to create folder: /external_sd/TWRP (errno=30)".
Philosopheur
Forum Posts: 16
2013/05/25 - 10:05
It installs and rue ?  very fine on the V973 with the new Firmware 3.0 (Android 4.2.2).  :-)
Are you using original stock ROM ONDA V30 or custom. ROM v30 like Kasty ?
Balrog
Forum Posts: 48
Thanks Received: 15
2013/05/26 - 02:47
The first install was with the original Onda V3.0 Firmware for V973 V1. There comes the "(errno=1)"-error if I want to make a full backup to the external sd.
The second time was with the Kasty modified rom 3.0 for V973 V1. This time the "(errno=30)"-error comes if I try to backup to the external sd.
Backup to the internal sd was in both cases okay and I am able to mount and access every partition in the built in file manager.
Philosopheur
Philosopheur
Forum Posts: 16
2013/05/26 - 11:27
So I have a problem, but I don't know where (perhaps because mine is a V972 v2 firmware) !!!
Balrog
Forum Posts: 48
Thanks Received: 15
2013/05/26 - 19:47
Just as a report: I successfully restored a full system backup (from the internal sd of course) to the V973 V1. The TWRP is really useful! :-)
ultrawires
Forum Posts: 11
2013/05/27 - 03:49
I'd successfully backed-up and restored from extsd, V973V1 with Kasty's lastest custom firmware -  TWRP 2.5.0.0.
Balrog
Forum Posts: 48
Thanks Received: 15
2013/06/29 - 12:50
Hi @ankar84!
Do you think you can have a look into the partitions of the new firmware 3.2?
Onda changed with version 3.2 the partitions and the TWRP 2.5.0.0 does not run anymore on my V973 V1.
I think it has the same partitions as V972 as I am able run TWRP 2.5.0.0 till firmware 3.0 without problems.
Thanks in advanvce,
Balrog
ankar84
Forum Posts: 13
Thanks Received: 28
2013/07/05 - 20:17
Check this one...
admin, Balrog
Balrog
Forum Posts: 48
Thanks Received: 15
2013/07/06 - 01:00
Sorry to say, but after flashing the reocvery and reboot to recovery my 973 stuck at the A31-Boot-Logo and I have to flash the firmware new via PhoenixSuit.
66 Guest(s)
Devices in use: Desktop (57), Phone (9)
