Android system:Â onda/fiber_ondama975q9/fiber-ondama975q9:4.4.2/KOT49H/20131227:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.94 (free version)
- added Google Experience Launcher (GEL) in addition to Onda stock launcher
- New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
- edit 2014/04/07: released new custom firmware update (kasty-onda_v975_v1-442-v44-rooted0b.zip)Â to fix a small issue with the virtual keyboard
Download: kasty-onda_v975_v1-442-v44-rooted0b.zip Â
(updated 2014/04/07)
xbeaviesx, ulli01, Steiner1967 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2014/03/30
Can you please update the link to the ROM ??
It only shows:
Error 404 - Not Found
We're very sorry, but that page doesn't exist or has been moved.
Please make sure you have the right URL.
If you still can't find what you're looking for, try using the search form below.
Greetz dudurma
The link is correct, but it looks like there a problem with the url rewriting on our server, I am looking at it right now, I'll post when it is fixed.
There was a weird bug with a Wordpress plugin, it should be fixed now.
I have posted an update fixing a small issue with the virtual keyboard, see post #1.
There is no need to update if you are having no issues.
Firmwares are built to special tablet models, I don't think the firmware published in post #1 would work on V975 V3 or V975s which are different models.
Cheers
2014/02/26
Ah ok thanks. I believed the "s" version was the same but I see it uses an AllWinner A31s.
Any idea what the easiest root method would be?
Firmwares are built to special tablet models, I don't think the firmware published in post #1 would work on V975 V3 or V975s which are different models.Cheers
2014/05/12
Hi
I installed this firmware. My tablet is very slow. Any idea what might be wrong? Also I don't see an option to select ART as run time in developer settings.Isn't that a part of KitKat? Another issue is that the youtube downloaded videos that were already present n memory card is not playing properly but newly downloaded videos are playing fine. Anyone got resolution for these issues ?
74 Guest(s)
Devices in use: Desktop (67), Phone (7)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
