[ ROM ] Onda V975 / V979 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.2 (2013-12-27)
ioannis_s
2014/03/01 - 22:25
I have an Onda V975.
I have ordered a micro HDMI to HDMI cable from Onda, which theoretically was supporting my tablet, but I can not get it to work. My TV does not see the tablet connected on the HDMI port. Does anyone know some more information that maybe I am missing?
PS 1: I have enabled the HDMI output in the android menu (under display settings), probed all the available resolutions too.
PS 1: I have try'ed to cut it a little bit (in order the micro HDMI pin to be longer )
PS 2: The cable still works fine fine my Sony NeoV cellphone and my tv (Samsung ue46c7000)
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
2014/03/02 - 10:58
You probably need to cut it back even more
and/or
cut out the casing of the tablet to allow the connector to go in fully. That worked for me on a V813
Pingu
2014/03/28 - 15:28
If anyone is interested, I have just posted a custom Android 4.4 KitKat firmware for the V975 (V1) :
http://www.arctablet.com/blog/forum/onda-v972/rom-onda-v975-v979-v1-hardware-android-4-4-2-kitkat-root-custom-firmware-v4-4/
NicholasMora
2014/04/17 - 10:10
Hey guys!
Im just wondering if anybody tried to install this firmware on V3 version of V975? Does it work?
Surfal
2014/04/17 - 22:02
I just recieved a V979 off Aliexpress.
So the v979 is basically the Foreign version of the v975 ? And does anyone know if there was more than 1 version hardware or a way to check the verison #
149 Guest(s)
Devices in use: Desktop (138), Phone (11)
spiik
nikitamaan
VMILCINOV
