[ ROM ] Onda V975 / V979 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.2 (2013-12-27)
Thanks Received: 3170
2014/01/15 - 12:32
Here is latest Android 4.2.2 Jelly Bean update for the Onda V975 / V979 tablet (hardware V1) based on newest Onda firmware release version 3.3.2 published 2013/12/27.
(V975_Core4_V3.3.2_v1.rar / V975 Core4_V3.3.2_v1.img)
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #3 SMP PREEMPT Sat Nov 16 09:48:01 UTC 2013
Android system: onda/fiber_ondama975q9/fiber-ondama975q9:4.2.2/JDQ39/20131226:eng/opinions-on-teclast-p90hdst-keys
ro.reversion.aw_sdk_tag=exdroid4.2.2_r1-a31-v3.3
Onda_V975_V1_FW332_about_b.pngImage Enlarger
  • root with latest SuperSU 1.89 (free version)
  • system default setup English
  • added Google Experience Launcher (GEL) in addition to Onda stock launcher
  • New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support.
Onda_V975_V1_FW332_root_b.pngImage Enlarger
I do confirm this firmware works fine on a Onda V975 (V1) and the accelerometer issues from previous custom firmwares has been fixed.
Onda_V975_V1_FW332_storage_b.pngImage Enlarger
Onda_V975_V1_FW332_apps_b.pngImage Enlarger
Thanks to sclstore.fr for lending me a test tablet to debug my custom firmware problems.
Denialmix, 0ne0ne0n, thorstenh, xbeaviesx
josephohare007
Forum Posts: 11
2014/01/15 - 14:12
will this work on a V975M? if yes any idea what use to upgrade with I used to use  phoenixsuite 1.8 but the device is not seen..!
2014/01/15 - 14:15
The firmware is designed for the V975, it won't work on the V975M.
josephohare007
Forum Posts: 11
2014/01/15 - 16:09
Many thanks for the quick reply...  I'll also got the  V972 with your great rooted code.....  I was hoping the same for the  V975M...  which is a great device even worked out how to root it!, but lots of app don't work on it and no 4K player!
please keep me posted ( everyone  I should say) on dev on the  V975M
thx.
Denialmix
2014/01/15 - 17:22
why Onda put similar name for completely different product? 8-O
Many thanks for new Kasty firmware! just what I needed!
josephohare007
Forum Posts: 11
2014/01/16 - 14:21
any plan afoot to include the V975M in  your  Kasty code releases?
0ne0ne0n
2014/01/17 - 11:38
Massive thanks for your rom and your hard work. I'm going to test on this weekend.
Good job, as always.
l_themis
Forum Posts: 22
2014/01/18 - 19:38
Perfect as always! Now everything is working great (except the HDMI out)
Thanks admin
badda
2014/01/25 - 08:34
Onda v975 does not have a home button, so how can I put it into flash mode?? The referenced flashing tutorial relies on a home button to be present. I tried the volume button instead - did not work. Any help is greatly appreciated :-)
opirsone
2014/01/25 - 19:25
Hey guys, I have an Onda V975 that I am trying to flash. When I get to the step of putting the tablet in a flash mode, I hold thevolume minus button, plug it, and then start pressing the home button simultaneously, I get a “Windows” dialog box saying that the device was detected and will try to install the software (Windows basic procedure when you plug in a new device). However; PhoenixSuit doesn’t seem to detect the device at all. Or i plug the usb when the tablet is on,Phoenixsuite recognize it,but when start the upgrade the tablet disconnect and the pc don't recognize the device!
Any help please!!?
2014/01/25 - 19:50
Since there is no home button, instead try using the others hardware buttons, try Vol- or Vol+.
badda
2014/01/25 - 20:06
Ok, tried again the volume key ... worked this time. Thanks guys :-D
badda
2014/02/01 - 17:43
I have two Onda 975, flashed them both with this ROM. On one of the two, camera is not working any longer. When starting the camera app, I get the error message "Unfortunately, Gallery has stopped". Anybody else has this problem? Is there a solution?
bitacora217
2014/02/02 - 13:08
will this work on a V975S? if yes any idea what use to upgrade with I used to use  phoenixsuite 1.8 but the device is not seen..!
2014/02/02 - 13:32
It's quite unlikely this firmware will work on the Onda V975S, both tablets have different hardware.
69 Guest(s)
Devices in use: Desktop (63), Phone (6)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
