[ ROM ] Onda V973 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.1 (2013-11-21)
2013/12/08 - 13:37
Here is latest Android 4.2.2 Jelly Bean update for the Onda V973 tablet (hardware V1) based on newest Onda firmware release version 3.3.1 published 2013/11/21.
(V973_Core4_v3.3.1_v1.rar)
Manufacturer revision history: (translated from Chinese)
1 new boot logo
2. new Onda desktop
3. underlying SDK upgrades, system stability and compatibility enhancements
4.Miracast function optimization
5. system comes with software to increase multi-language support
6. fixes known software issues
7 Set – stored under the new built-in disk total capacity display Note: 1, the firmware package containing Brush tutorial and Brush tool, use desktop computers Brush; 2, Brush risk, please before Brush carefully read the tutorial; 3, the V2 firmware version applies only to models; 4, check the version number, see the back of the fuselage SN code 9,10 bit;
Firmware build information:
Linux Kernel: Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Mon Nov 18 05:37:44 UTC 2013
Android system: onda/fiber_onda974q9/fiber-onda974q9:4.2.2/JDQ39/20131119:eng/opinions-on-teclast-p90hdst-keys
ro.reversion.aw_sdk_tag=exdroid4.2.2_r1-a31-v3.3
  • root with latest SuperSU 1.80 (free version)
  • system default setup English
  • removed Onda new launcher
  • optional Team Win Recovery Project (TWRP) easy install package
  • New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
After flashing the tablet, a Setup Wizard may appear on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should now be displayed.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an Onda V973v1 tablet to test the custom firmware.
(pictures from Onda V972 v3.3.1 firmware)
QwertyX, chittu
drunja40
2013/12/08 - 18:30
Can't flash( Got a permanent message "Begin to upgrade Firmware to device" in Phoenix. After cancelling the upgrade image.jpgImage Enlarger
ricky88
Forum Posts: 17
2013/12/09 - 10:36
Hi Admin,
I just downloaded the firmware but it is version 3.2.1 not 3.3.1 (it has the Chinese girl boot logo and old style desktop) what have I done wrong? The RAR file is labeled as 3.3.1 but when you unpack it it's version 3.2.1
Thank you very much!
dronchik3000
Ukraine
2013/12/09 - 19:30
It is 3.2.1 version. (((
2013/12/09 - 19:35
Sorry guys, it seems to be a mistake on my side, I'll double check that and re-post a proper firmware.
2013/12/10 - 00:07
I have rebuilt and updated the custom firmware in post #1:
I am afraid that I can't verify if this custom firmware works as I don't have an Onda V973v1 tablet to test it, feedback is welcome.
ricky88, dronchik3000, 41795
msav
Forum Posts: 71
Thanks Received: 13
2013/12/10 - 14:54
Thanks Admin,
I am patiently waiting for a v973 v2 rom.  I am in no real hurry as I just got this tablet. and the existing firmware is sufficient.  In fact I would not be heartbroken if you waited until KitKat.
Keep up the great work, I will test it out as soon as you post it as I am just using v973 for tinkering.
2013/12/10 - 22:52
Hey msav,
It's in the plans Wink
If Onda KitKat release doesn't surface by mid next week, a custom firmware for the Jelly Bean V3.3.1 should be posted.
seek
dronchik3000
Ukraine
2013/12/12 - 17:49
Thanks, but I have a problem, when OS is started I get an error in launcher application and desktop isn`t available. Onda v973 v1. Installation without format.
Sorry :) if in installation choose format all data, everything allright. Thanks.
QwertyX
2013/12/13 - 18:14
It seems to be - a good one.
Thank you.
QwertyX
2014/02/08 - 07:16
Dear Admin, do you have plan for new version for v973 v1?
Here it is http://www.onda.cn/Tablet/ProductInfo.aspx?ProductId=250&d=down
I really hope you do :). Your versions are most stable so i am using them for a long time.
badda
2014/02/20 - 07:48
How can I tell if my Onda V973 is a v1 or v2 hardware?
badda
2014/02/20 - 08:03
Just found the answer myself ... well hidden in some Chinese ;-)
to check the version number, see the back of the fuselage SN code 9,10 bit
amartor
Forum Posts: 12
2014/03/10 - 23:16
Hello guys, is there a kasty custom rom v3.3.1 or higher, for the V973 (v2 hardware) tablet? Last custom rom I was able to find is the v3.2.1 from 2013 July.
Thank you
Currently Online: Azabatxe1
153 Guest(s)
Devices in use: Desktop (146), Phone (8)
jacksonrid
usdown
ibob64
