[ROM] ONDA V972_V1 - Kitkat 4.4.2 Rooted (Final release 28.12.2013)
vel2000
Forum Posts: 61
Thanks Received: 44
31
2013/12/30 - 03:46
yepp, there is definitely a bug, which prevents /system from mounted as rw.
I will check this.
kami2lo
Forum Posts: 13
32
2013/12/30 - 10:59
I will check this.
Thx vel2000. I know basics but don't know how to fix it by my self.
After two days of use, I have to say that it's cool to have android 4.4, but Onda must definitely have some work, IMO a little underdeveloped
btoribio
33
2013/12/30 - 16:38
Any chance to have a rooting script?
Like "ROOT_Limpieza_Logo_V3.zip" that we can run from local update?
BoB77
Forum Posts: 28
34
2013/12/30 - 16:47
kami2lo said
msav look againg, it's final! Work greate.
maxxxy to get Phoenix suite 1.0.8 install ver. 1.0.6 and update it.
Come on! There is still beta FW as it is written on Onda's website
http://onda.cn/Tablet/ProductInfo.aspx?ProductId=239
kami2lo
Forum Posts: 13
35
2013/12/30 - 18:57
Yes, i know, but i thought that demo was beta version, this rom supposed to be the final... will wait and see
vlad0n
Forum Posts: 19
36
2013/12/30 - 19:08
kamil2lo, me too .  I think that demo was beta... I don't know what on the onda.cn they write that rom is beta...
msav
Forum Posts: 71
Thanks Received: 13
37
2013/12/30 - 19:59
There changed the file however they did not change the description. It still says beta. The previous file that was up for download. on dec 28 was named v972_v1_v4.4demo.rar
the new file that is up for download is named V972 Core4_v4.4_v1.rar
so either they made a mistake and did not edit the description or the new file is just a new beta.
BoB77
Forum Posts: 28
38
2013/12/30 - 21:56
Hope it's still beta. Observed some stability issues - unexpected termination of particular running processes. It didn't occur on 3.3.1 FW.
gvtt
39
2013/12/31 - 00:13
everytime i enter adblocker i see it is disabled. is the /rw problem causing this?
vel2000
Forum Posts: 61
Thanks Received: 44
40
2013/12/31 - 02:27
adaway/adblocker need write access to "/system/etc/hosts" but can't get it
It seems that there are some "security mechanisms" built-in (or in Phoenix?).
  • if you change something in the "boot" partition, the Rom is not flashable!
  • unpacking and repacking "system" (even without any changes) leads to the ro/rw issues.
I am working on this.
vel2000
Forum Posts: 61
Thanks Received: 44
41
2014/01/02 - 12:21
UPDATED firmware:
  • the problem, that /system couldn't be mounted as read/write, is solved!
see first post in this thread
The following users say thank you to vel2000 for this useful post:
gvtt, bomusic
kami2lo
Forum Posts: 13
42
2014/01/02 - 12:24
vel2000 said
UPDATED firmware:
rispekt :)
The following users say thank you to kami2lo for this useful post:
bazk123
bazk123
London
Forum Posts: 51
Thanks Received: 5
43
2014/01/02 - 23:57
Big problem trying to up-grade to the working 4.4 kitkat, cannot get the Onda 972 v1 to upgrade, it can't find the USB via Phoenix Suit, tried on 1.0.6 & new 1.8 same problem, tried also in two modes, at the quick boot & cold boot, press & hold Home button, install the USB in the PC, hit power button, (while holding down the home button) medium to fast over 10 times, nothing :(
OK sorry guys my Laptop seems to have USB issues either Hardware or software, will install W7 again tomorrow, then we will see if its software, but in the mean time, used my sons vista PC, work like a charm install the up-dated kit-kat .:)
gvtt
44
2014/01/03 - 03:07
 problems i had with the new fw first when the screen goes to screen saver mode it does not come back until i reboot second it is a little laggier/heavier compared to 3.3.1
Jobster
45
2014/01/03 - 16:46
@Vel2000 Thank you so much for your effort!!
Can someone give a review about this Rom?
Currently Online: Azabatxe1
138 Guest(s)
Devices in use: Desktop (132), Phone (7)
jacksonrid
usdown
ibob64
