[ ROM ] Onda V972 (V2 hardware) Android 4.4.2 KitKat root custom firmware V4.4
rcade
2014/06/10 - 14:50
Apps missing from the Play store- you can't install Google+
Android Numpty
Forum Posts: 13
2014/07/12 - 22:06
I can't get any widgets whatsoever, apart from the google search bar - that's the only option available to select.
I can't even get an effing clock!
Haven't come across a fix either so I'm debating whether to go back to JB or notCry
Not holding my breath for help - seems everyone has deserted this thread.
eos400
Forum Posts: 14
2014/08/09 - 16:15
Io sono Tornato a JB.
KitKat odiosa.
Grazie comunque ad ARCTABLET per l' eccellente lavoro fatto.
W 4.2.2. JB Arctablet.
____________________________________________________
I am returning to JB.
KitKat hateful.
Thanks anyway to ARCTABLET 's excellent job done.
Only the stupid idea never changes !
latumus
2014/09/21 - 19:44
i have the widget problem as well is anyone using another rom with kitkat? a custom one maybe which supports the volume buttons?
eos400
Forum Posts: 14
2014/09/21 - 23:54
Ciao, io ho provato la ROM originale di ONDA per V972, e funzionavano i tasti volume, ma l'ho disinstallata perché la KitKat era spesso crash.
Poi ho provato la KitKat di Arctablet ma mi data tanti problemi e a me non piaceva.
Allora sono tornato alla 4.2.2 Arctablet e tutto funziona benissimo.
Per me non è indispensabile passare a KitKat, Jally Ben funziona in maniera egregia.
Hello, I tried the original ONDA ROM for V972, and worked the volume buttons, but I uninstalled because the KitKat was often crash.
Then I tried the KitKat Arctablet but I date a lot of problems and I do not like it.
Then I went back to 4.2.2 Arctablet and everything works fine.
For me is  not essential to move to KitKat, Jally Ben works beautifully.
maildr
2014/11/15 - 14:00
Is there any alternative recovery for this rom?
2014/11/15 - 18:12
The firmware from post #1 includes a stock recovery.
TWRP port and an easy install package has been built for earlier firmwares, but I don't think these will work with this KitKat firmware.
diwrat
2014/12/13 - 17:51
has anyone installed 4.4.2 and had few problems so kept this version or has everyone gone back to JB?
any other options out there?
thanks
eos400
Forum Posts: 14
2014/12/13 - 18:21
thanks
I happily returned to Jally Ben edited by Arctablet ... Superb.
Kit Kat nails this tablet.
To me it is fine not to step 4.4.2.
Bye
Io sono felicemente tornato a Jally Ben modificato da Arctablet... Superbo.
Kit Kat inchioda questo tablet.
A me va benissimo così non passo a 4.4.2.
Ciao.
stevieo63
2014/12/13 - 18:39
Kit Kat was too unstable. JB doesn't work much better, but it's more consistent. I went back to JB.
eos400
Forum Posts: 14
2014/12/13 - 19:03
I believe what you say.
But I must say that to me JB does not create any problem.
Then it depends on what you want from V972.
I use it to YouTube; Web; movie; Games ..... okay, no crashes
Bay
Credo a quello che dici, ma a me JB non crea alcun problema.
Poi dipende da quello che si vuole da V972.
Io lo uso per YouTube; Web; Film; Giochi ..... va bene, non si blocca
Ciao
Android Numpty
Forum Posts: 13
2014/12/21 - 16:19
Anyone wanting to get KitKat on their V972 should try CM11
You can get it here with full tutorials:
http://www.slatedroid.com/topic/97866-custom-rom-cyanogenmod-11-442-for-allwinner-a31-by-christiantroy-update-2014-04-19/
Ericane
2015/06/03 - 09:23
I am going to try this ROM 🙂
eos400
Forum Posts: 14
2015/06/03 - 12:48
Io ho V972 V2 buona ROM ma io l'ho disinstallata perchè mi dava problemi e tornato a JB.
Da un mese ho messo la Cyanogenmo 11 (funziona che è una meraviglia).
Consiglio Cyanogenmod 11
I V972 V2 good ROM but I uninstalled because it gave me problems and returned to JB.
For a month I put Cyanogenmo 11 (it works like a dream).
Council CyanogenMod 11
kimera761
2015/06/18 - 11:23
Puoi postare il link della ROM? Magari anche il procedimento?Grazie sin d'ora EOS400 😉
_________________________________________________________________________________________
Please, can you link me please and explain the update process?Thanks !
75 Guest(s)
Devices in use: Desktop (67), Phone (8)
cutierogue
hans41
rickybk
