1 new boot logoÂ2. new Onda desktopÂ
3. underlying SDK upgrades, system stability and compatibility enhancementsÂ
4.Miracast function optimizationÂ
5. system comes with software to increase multi-language supportÂ
6. fixes known software issuesÂ
7 Set – stored under the new built-in disk total capacity display Note: 1, the firmware package containing Brush tutorial and Brush tool, use desktop computers Brush; 2, Brush risk, please before Brush carefully read the tutorial; 3, the V2 firmware version applies only to models; 4, check the version number, see the back of the fuselage SN code 9,10 bit;
Linux Kernel:Â Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Mon Nov 18 05:37:44 UTC 2013
Android system:Â onda/fiber_onda978q9p6/fiber-onda978q9p6:4.2.2/JDQ39/20131119:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.75 (free version)
- removed Onda new launcher
- optional Team Win Recovery Project (TWRP) easy install package
- New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
After flashing the tablet, a Setup Wizard may appear on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should now be displayed.
konchog uma, Philosopheur, karmen1983, peppev4, hyp3r If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Thanks for your supportÂ
In current form, our custom firmware is meant to be flashed with PhoenixSuite as mentioned in post #1, you can't install it thru TWRP.
2014/04/15
2 days with the rom and seems to be the most stable of which I've tried. The only weird problem is that I cannot see the "Running" tab under "Settings/Apps". Here is the logcat of the error:
D/dalvikvm( 5490): GC_CONCURRENT freed 98K, 8% free 10857K/11732K, paused 3ms+3ms, total 24ms
D/dalvikvm( 5490): WAIT_FOR_CONCURRENT_GC blocked 15ms
F/Environment( 5490): Static storage paths aren't available from AID_SYSTEM
F/Environment( 5490): java.lang.Throwable
F/Environment( 5490): at android.os.Environment.throwIfSystem(Environment.java:637)
F/Environment( 5490): at android.os.Environment.getExternalStorageDirectory(Environment.java:316)
F/Environment( 5490): at com.android.settings.applications.ManageApplications$TabInfo.updateStorageUsage(ManageApplications.java:333)
F/Environment( 5490): at com.android.settings.applications.ManageApplications$TabInfo.setContainerService(ManageApplications.java:234)
F/Environment( 5490): at com.android.settings.applications.ManageApplications$2.onServiceConnected(ManageApplications.java:1227)
F/Environment( 5490): at android.app.LoadedApk$ServiceDispatcher.doConnected(LoadedApk.java:1101)
F/Environment( 5490): at android.app.LoadedApk$ServiceDispatcher$RunConnection.run(LoadedApk.java:1118)
F/Environment( 5490): at android.os.Handler.handleCallback(Handler.java:725)
F/Environment( 5490): at android.os.Handler.dispatchMessage(Handler.java:92)
F/Environment( 5490): at android.os.Looper.loop(Looper.java:137)
F/Environment( 5490): at android.app.ActivityThread.main(ActivityThread.java:5041)
F/Environment( 5490): at java.lang.reflect.Method.invokeNative(Native Method)
F/Environment( 5490): at java.lang.reflect.Method.invoke(Method.java:511)
F/Environment( 5490): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:817)
F/Environment( 5490): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:584)
F/Environment( 5490): at dalvik.system.NativeStart.main(Native Method)
D/dalvikvm( 5490): GC_CONCURRENT freed 350K, 9% free 11162K/12252K, paused 2ms+3ms, total 23ms
D/dalvikvm( 5490): WAIT_FOR_CONCURRENT_GC blocked 7ms
D/dalvikvm( 5490): GC_FOR_ALLOC freed 65K, 9% free 11435K/12532K, paused 20ms, total 20ms
I/dalvikvm-heap( 5490): Grow heap (frag case) to 14.096MB for 2359312-byte allocation
D/dalvikvm( 5490): GC_FOR_ALLOC freed 1K, 8% free 13737K/14840K, paused 20ms, total 20ms
D/dalvikvm( 5490): GC_CONCURRENT freed 4K, 8% free 13733K/14840K, paused 2ms+2ms, total 22ms
D/dalvikvm( 5080): GC_CONCURRENT freed 366K, 11% free 8720K/9784K, paused 3ms+2ms, total 24ms
F/Environment( 5490): at com.android.settings.applications.ManageApplications$ApplicationsAdapter.rebuild(ManageApplications.java:645)
F/Environment( 5490): at com.android.settings.applications.ManageApplications$ApplicationsAdapter.resume(ManageApplications.java:569)
F/Environment( 5490): at com.android.settings.applications.ManageApplications$TabInfo.resume(ManageApplications.java:298)
F/Environment( 5490): at com.android.settings.applications.ManageApplications.updateCurrentTab(ManageApplications.java:1201)
F/Environment( 5490): at com.android.settings.applications.ManageApplications$MyPagerAdapter.onPageScrollStateChanged(ManageApplications.java:505)
F/Environment( 5490): at android.support.v4.view.ViewPager.setScrollState(ViewPager.java:392)
F/Environment( 5490): at android.support.v4.view.ViewPager.access$000(ViewPager.java:84)
F/Environment( 5490): at android.support.v4.view.ViewPager$3.run(ViewPager.java:237)
F/Environment( 5490): at android.view.Choreographer$CallbackRecord.run(Choreographer.java:749)
F/Environment( 5490): at android.view.Choreographer.doCallbacks(Choreographer.java:562)
F/Environment( 5490): at android.view.Choreographer.doFrame(Choreographer.java:531)
F/Environment( 5490): at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:735)
F/Environment( 5490): at com.android.settings.applications.ManageApplications.updateCurrentTab(ManageApplications.java:1212)
D/android.widget.GridLayout( 5490): vertical constraints: y2-y0>=96, y2-y1<=38, y1-y0<=53 are inconsistent; permanently removing: y2-y1<=38.
W/dalvikvm( 5490): threadid=15: thread exiting with uncaught exception (group=0x40acd930)
E/AndroidRuntime( 5490): FATAL EXCEPTION: RunningState:Background
E/AndroidRuntime( 5490): java.lang.NullPointerException
E/AndroidRuntime( 5490): at com.android.settings.applications.RunningState$ProcessItem.updateService(RunningState.java:470)
E/AndroidRuntime( 5490): at com.android.settings.applications.RunningState.update(RunningState.java:969)
E/AndroidRuntime( 5490): at com.android.settings.applications.RunningState.access$100(RunningState.java:57)
E/AndroidRuntime( 5490): at com.android.settings.applications.RunningState$BackgroundHandler.handleMessage(RunningState.java:240)
E/AndroidRuntime( 5490): at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime( 5490): at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 5490): at android.os.HandlerThread.run(HandlerThread.java:60)
W/ActivityManager( 5595): Force finishing activity com.android.settings/.Settings
D/dalvikvm( 5595): GC_FOR_ALLOC freed 1816K, 31% free 28611K/40944K, paused 201ms, total 201ms
Android 4.4 KitKat custom firmware for the Onda V972 V2 just posted:
Currently Online: artnovabobo
97 Guest(s)
Devices in use: Desktop (81), Phone (17)
adison
Zenn
nicl
FreddyBerlin
Lioterson
titi1975
