[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.1 (2013-11-22)
wooley
Forum Posts: 18
76
2014/05/15 - 22:48
just flashed kasty again on my onda v972...
works fine,all works,no fc whatsoever
 i had to install all my apps manually
in cm11 after setup auto install my apps
performance is great but cheat....antutu is 19000 but in antutu x 12000(anti cheat)
battery backup moderate..3-4 hours internet
will test following weeks to see how stable
Onda V972 V1 Running CM11 KK4.4 Cyanogenmod
greg22
Forum Posts: 21
77
2014/05/16 - 21:40
told ya !! :)
cm11 or other kitkat 4.4.x sucks for onda v972 v1. :)
Nothing beats Kasty's: kasty-onda_v972_v1-422-v331_20131122 ROM
Onda V972, V1 & kasty v331_20131122
wooley
Forum Posts: 18
78
2014/05/16 - 22:11
I didnt change from cm11 because it isnt good...
I just like to experiment with diffrent roms to see which is best for me.
Cm11 worked fine for me on my v972 v1
But i was curious about the high antutu score in kasty
But when u run antutu x (anti-cheat) the score is the same as in cm11
But for now i want to test if kasty is stable like cm11 proved the last weeks.
The original onda rom 4.1 was not stable on my tablet:-)
Ciao
dejavue
79
2014/06/17 - 11:44
Well I lost my cam. It was working pretty good in kitkat v2 but it was laggy and I wanted to go back to 4.2.2 and I tried every version v1-2-3 no camera at all. Then I tried kitkat again (I think v1 kitkat) again no camera :/ what is happening
Andrew
Bucks., UK
Forum Posts: 27
80
2014/06/17 - 12:58
Thats odd I did the same tried KitKat found a lot of FCs then went back to v3.3.1 (4.2.2) and all was fine. Did you do the format when updating the firmware?
Andy
dejavue
81
2014/06/17 - 13:14
Andy
Well I went completely back to the stock Rom (the tablet sold as artes q972 in Turkey) and in that rom no problem at all. I rooted it with Onda v972 root zip. I formated every time (also tried w/out format) but no go. My fw is now 3.2 but at least everything is working till I get back home.
angelo9888
82
2014/06/25 - 15:36
does this firmware work on Archos 97 platinum?
has anyone tested it?
vivichrist
83
2014/07/09 - 15:20
Please disregard my last comment as I really just needed an OTG cable. I am currently having issues with some process interrupting touch and slide resulting in double tap and this was not due to dust on the screen.
Watusi
84
2014/07/18 - 04:11
Andy
i return my rom from KK to JB...no problem at all,i format during flashing
wooley
Forum Posts: 18
85
2014/07/30 - 17:59
Just flashed back from last cm11 version.
Was not stable enough for daily use.
Kasty gives less time an fc and has better battery life.
Also installed google now launcher...stable as rock now and battery 2-3 days stbye+mail
Flashing no probs with phoenix 1.08 with format
Great work devs
Thx
tweakmorning
86
2014/08/29 - 21:26
sorry wrong topic
deton24
87
2016/02/14 - 22:32
Is it possible to extract only kernel from this ROM and apply it to CM 11 4.4.2 ROM
http://www.slatedroid.com/topic/97866-custom-rom-cyanogenmod-11-442-for-allwinner-a31-by-christiantroy-update-2014-04-19/
to fix HDMI there, since it is trouble caused by version of kernel?
It's SDK 3.2 issue, Christian Troy says it's kernel's issue, looks like it is fixed with 3.2.1 firmware and it's custom ROMs. He stopped at 3.2 kernel.
anavrin
88
2016/06/23 - 19:40
Hello.
Used this rom since yesterday. Today i installed 2 camera apps from the play store and used arctools to reboot. Now the tablet is dead. No sign of life on pressing power. No TWPR possible to start. No chance to flash the rom again with Phoenixsuite. Battery was as 80%.
What else can i try? Thank you.
deton24
89
2016/06/23 - 20:41
Make sure that tablet is really off.
Press power button for some longer time, then try again, then again press button for some longer time, and check.
You can also check on some other computer, and be sure that your drivers has been installed properly, you can see something in device manager, whether appears anything during plugging.
anavrin
90
2016/06/23 - 21:10
Thanks. Itried that all. No reaction. If i press Home and power same time its a very quite klick sound after 5 sconds from inside the tablet.
The PC has all drivers installed. It was used to flash yesterday.
I just made a reboot with arctools. was this fubction tested?
Edit: After one day charging the device could be flashed again.
42 Guest(s)
Devices in use: Desktop (33), Phone (9)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
