2014/01/30
Thank you for your answers. This maybe an early demonstration hardware version, without any labels. I tried the v2 and v3 roms, but camera did not work with the v2, and with v3 not even started. Camera worked only with 4.4.2_v1_kitkat version, but I think this is to slow. Other functions work properly. I'll try other rom versions too.
2013/06/05
I find that power drain is not that much different to previous releases, maybe your battery is getting on a bit. I find charging with a 1000ma charger only takes a few hours from 15% to over 95%. I have been using JuceDefender recently and it regularly says my battery is lasting x2 as long and sometimes even x3 or more. Hope this helps.
Andy
2014/03/27
Best rom so far for v972 v1
i bought a second hand v972 V1 but it was having Fc evrytime
firmware was android 4.1 from onda
nothing helped,even replacing launcher with nova
after this i flashed 4.4.2 kitkat but same reult little better with nova but still not suitable for daily use
yesterday i flashed this 4.2.2. kasty...wow
very responsive almost no fc
installed many things and all work great
tried to overclock but not stable,freeze antutu
so back to normal whicjh is great
great workk devs
thx
Onda V972 V1 Running CM11 KK4.4 Cyanogenmod
2012/12/06
hello everyone,Â
need your valuable help. By mistake I installed the onda v812 firmware on my soons onda v972. Â I tryed to install the 972 firmware but when I connect the usb cable (while holding the go to home button) the screen turns on, and the computer shows two new drives, then I push the power on button several times and the tablet is not recogniced by the phoenix program.
Any ideas on how to solve this?? Thank you very much.
2014/03/27
tested this rom in us and south afrika and england.....
quite stable (better than 4.4)
sometimes in internet it crashed and i had to switch off with power button
(system ui has stopped)
for the rest great rom
performance antutu 19000
battery backup moderate 5-6 hours internet...
how to reset battery stats in twrp?
thx dev
2013/05/16
Fine Rom but I've noticed that the screen slider for screenbrightness can't be slide completly to the left.
The minimum is almost 1/3. But in a room, not directly in sunlight, Â this is even to much.
So it would be better if screenbrightness can be set lower than the lowest position now ...
Batteryduration is already so a pain with this tablet.
2013/03/07
My Onda v972 v1 16gb was slow on CM11. Also watching flash video was crap. I installed it 2 times, the same problems.
Even Vel2000's KK rom is better than CM11, though bugy.
But nothing beats Kasty's:Â kasty-onda_v972_v1-422-v331_20131122 ROM.
I like stable roms and hate fancy unstable ones.
Onda V972, V1 & kasty v331_20131122
39 Guest(s)
Devices in use: Desktop (36), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
