[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.1 (2013-11-22)
Andrew
Bucks., UK
Forum Posts: 27
2013/11/30 - 08:23
All seems fine, the WiFi for me connects at 150M as did 3.2.1 and 3.2 before it. Great update, good to know the 972 still gets updates. Just read about KitKat on the onda news site, looking forward to it.
Andy
btongkm
2013/11/30 - 16:55
billkaroly said
WIFI is acting strangely. I have a router and an extender. The tablet will connect to the router on a weaker signal but the extender will not connect at all. The strength meter on the extender shows a good strong signal until I try to connect. Then it shows a weak signal and never connects. Both the router and extender are Netgear products. None of my other devices have any trouble connecting to either one. Seems very odd to me.
Wifi was working for a while, and could not connect after few apps upgrade. Now I switch it back to the V972Core4_v3.2.1_v1.
Frown
tipitelis
2013/12/01 - 16:12
First of all thanx to the admin and all the people that are so helpful!
I have a V1 V972 and I have succesfully installed and used every original and kasty firmware up to this one!
I flashed it through phoenixsuite but when the procedure ends, nothing happens.
Usually, after the flash, the pc recognizes the usb device making the specific noise and the tablet screen turns on or shows the battery. But with this firmware nothing happens. The tablet can't be turned on, the screen shows nothing but there must be something running because I have to press the power button for 10 secs and hear a little noise before I can flash it again.
It is not bricked because I flashed it with the previous firmware and works just fine. I even tried earlier phoenixsuite versions but nothing happens!
Thank you in advance!
tipitelis
2013/12/02 - 03:05
As it seems it resolved itself after installing it 3 times with the sd card removed!
vade
Russia
2013/12/02 - 12:18
Hello!I want to stock desktop.How to restore or install the default launcher Onda?
Andrew
Bucks., UK
Forum Posts: 27
2013/12/02 - 15:40
If you go into settings ->Apps find your Launcher and tap on it, then some way down the page tap on 'Clear Defaults'. Now when you tap the Home soft kay the ONDA will ask which launcher to use, select the green house launcher and use always.
Is that what you mean?
Andy
vade
Russia
2013/12/02 - 20:54
Andy
Thanks,but the button 'Clear Defaults' is not active.In the custom firmware V3.3.1. removed Onda new launcher,and I want the launcher which is the official firmware.How to install or return new official Onda launcher?
Andrew
Bucks., UK
Forum Posts: 27
2013/12/02 - 22:31
Oh .... I am at a loss then because 'Clear Defaults' is active on my v972 v1 with the v3.3.1 custom firmware. Perhaps someone else can help more.
Andy.
vade
Russia
2013/12/03 - 05:07
Well script or patch.How recovery new Onda launcher?
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/12/03 - 08:06
Maybe download and install the original Chinese version?
vade
Russia
2013/12/03 - 08:47
For what I put kasty firmware?I would not ask here,and install original firmware.Is there a solution?
greg22
Forum Posts: 21
2013/12/04 - 00:27
I have Onda v972 v1 16mb for 10 months. I charge tablet usually from 0% to 100%.
At the beginning, battery powered tablet for 6 hours. Now battery lasts just 2 hours. I flash tablet regular with new firmware with formatting partitions... I always use lowest brightness and sometimes even dimmer app.
Crap! I even need to take charger with me, when I go to school, etc...  Yell
So I need to order new set of batteries?!? Cause seems this one will die soon.
Onda V972, V1 & kasty v331_20131122
2013/12/04 - 00:42
greg22,
I don't have precise battery benchmarks with me, but 6 hours seem quite long.
It's best to compare all parameter being equals, that is for same tablet usage/running same apps on same firmware version. Actually older firmware were reported to give better battery life than current ones, I haven't timed them precisely but that could be one reason. Another is your battery wearing over time, that's normal if it received many charging/discharging cycles.
vade
Russia
2013/12/04 - 09:24
Admin,how to install or return "Onda Launcher new"?You might know,answer please!
2013/12/04 - 09:37
vade,
I don't have my V972 with me now so I can't check but if the Onda launcher file was removed it needs to be re-added in /system/app. You may check the Onda stock firmware for it.
149 Guest(s)
Devices in use: Desktop (143), Phone (6)
jacksonrid
usdown
ibob64
kawi
vetBro
