[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.1 (2013-11-22)
2013/11/22 - 20:37
Here is latest Android 4.2.2 Jelly Bean update for the Onda V972 tablet (hardware V1) based on newest Onda firmware release version 3.3.1 published 2013/11/22.
(V972_Core4_v3.3.1_v1.rar)
Manufacturer revision history: (translated from Chinese)
1 new boot logo
2. new Onda desktop
3. underlying SDK upgrades, system stability and compatibility enhancements
4.Miracast function optimization
5. system comes with software to increase multi-language support
6. fixes known software issues
7 Set - stored under the new built-in disk total capacity display Note: 1, the firmware package containing Brush tutorial and Brush tool, use desktop computers Brush; 2, Brush risk, please before Brush carefully read the tutorial; 3, the V2 firmware version applies only to models; 4, check the version number, see the back of the fuselage SN code 9,10 bit;
Onda_V972_fw_331_settings_about.pngImage Enlarger
Firmware build information:
Linux Kernel: Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Mon Nov 18 05:37:44 UTC 2013
Android system: onda/fiber_onda978q9/fiber-onda978q9:4.2.2/JDQ39/20131120:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU 1.75 (free version)
  • system default setup English
  • removed Onda new launcher
  • optional Team Win Recovery Project (TWRP) easy install package
  • New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
After flashing the tablet, a Setup Wizard may appear on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should now be displayed.
Onda_V972_fw_331_home_1024.pngImage Enlarger
Onda_V972_fw_331_apps_1024.pngImage Enlarger
adrianomm, billkaroly, Elvis_lives, elan71, Donkman, peppev4, nellslasher, Raheel963, superibor, TabletUser, DannyG, lee99
bogg
2013/11/22 - 20:56
Thx for this..
  I will follow up on this thread  :P
  This contains the latest tweaks that integrates the gamepad support and no onda 'airline' girl at the start?
Appreciate your work :D
The following users say thank you to bogg for this useful post:
wooley, Song Thuong
2013/11/22 - 21:00
You read well bogg.
toytherock
2013/11/22 - 22:05
Thank you so much for your hard work sir Admin. Have a nice day. :)
bobb
Forum Posts: 40
Thanks Received: 9
2013/11/22 - 22:32
very smooth and snappy!
Onda V972
Ainol Fire
iFive mini 3
Teclast P90HD
brad1601
2013/11/22 - 23:04
Thanks very much for your work! Good to see the 'old' onda is still getting updates!
bazk123
London
Forum Posts: 51
Thanks Received: 5
2013/11/23 - 01:22
Wicked Admin, wonderful work, working great :)
Philosopheur
Forum Posts: 16
2013/11/23 - 15:38
Hi admin,
Please don't forget 972 v2 Firmware, we expect it so much !!!
Thank
Tablette ONDA V972-v2 ROM STOCK 422 Root
renato0134
Forum Posts: 14
2013/11/24 - 15:30
I have the same problem with this version as with the previous version. I don't see my memory. I can't download or install anything.
"There is insufficient space on the device"
What can I do?
My tablet is v972 v1 32gb. I installed the correct version. Should I try v2 maybe?
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/11/24 - 21:15
Thanks for the update! The battery seems to be holding up well. Seems a bit sluggish to me but that could be because I have a Note 3. My one regret about this tablet is that it was not a real 1.5ghz device as advertised. 1.15ghz seems to be the fastest I can run mine at. We have two of the 972 v1 tablets and one of them has a nasty habit of resetting to factory default (sort of) for no reason. I use Apex Launcher and for CPU control I use No-Frills CPU.
Qesc
2013/11/25 - 14:09
Hi all,
could anybody tell me about the connection wifi, does it still drop all the time? thx a lot!!
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/11/25 - 18:14
WIFI is acting strangely. I have a router and an extender. The tablet will connect to the router on a weaker signal but the extender will not connect at all. The strength meter on the extender shows a good strong signal until I try to connect. Then it shows a weak signal and never connects. Both the router and extender are Netgear products. None of my other devices have any trouble connecting to either one. Seems very odd to me.
renato0134
Forum Posts: 14
2013/11/26 - 22:34
What can I do?
Anyone? Admin? Maybe? I would like a newer version than 3.0. But how to solve this problem?
weaver792
2013/11/28 - 15:01
Cool ROM, so far the best for battery duration and performances.
Is there any way to add the PS3 gamepad support? It would be perfect after this.
Thanks a lot!
peppev4
Italy
2013/11/28 - 18:52
Tank's a lot!Wink
78 Guest(s)
2 Guest(s)
Devices in use: Desktop (51), Phone (26), Tablet (1)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
