Phoenixsuit stuck at 100% during upgrade
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/03/13 - 08:20
I was trying to flash my V972 with Supernova 3.0 which I did. After doing so, the tablet would shut off when the screen turns off. I decided to flash v1.35 stock so I started Phoenix and at 44% I get an error with non English text. Tried again and still same thing. I downloaded 1.32 and tried with that and now Phoenix goes till 100% and just stops there, no success or fail message. I tried different laptops, same result and the tablet doesn't power on. Even when I connect the charger it doesn't show charging graphic.
Any ideas ?
msav
Forum Posts: 71
Thanks Received: 13
2013/03/13 - 16:27
Make sure to select format option when flashing with phoenixsuite. Also make sure you are using the cable that came with it.
The few times I had problems with phoenixsuite I just kept trying over and over The most I have had to do it is 3 times.
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/03/13 - 16:58
I tried more than 8 times and am using HTC cable which should be better. Did it ever stop at 100% with you ?
msav
Forum Posts: 71
Thanks Received: 13
2013/03/13 - 17:19
never at 100%  always around 60 - 70%
I would try a different cable, Shorter would be preferred.  also it may help to make sure the tablet is at least 80% charged. Of course with your current tablet state is impossible to verify
also make sure the firmware files your using are complete. if not sure re download them. Or use a firmware file that worked previously.
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/03/13 - 17:23
Will try a shorter cable, I haven't tried any other firmware as this is a new tablet but I tried with 1.32, 1.34 and 1.35. Downloaded katsy 1.35 and will try that. I left the tablet on charger over night so it should be fine.
When it stops at 80% does the tab start ?, when you connect the charger does it show charging ?
msav
Forum Posts: 71
Thanks Received: 13
2013/03/13 - 17:29
I know i had some issues with incomplete downloads on some of the foreign servers.
the kasty 1.35 image should be 486,780,928 bytes once unzipped.
Good Luck.
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/03/13 - 17:33
can you do md5 ?
2013/03/13 - 17:35
MD5:
295cc9a1bc0cb4af1d256232f5678bd8  V972Core4_v1.35.img
But that shouldn't be necessary as unzip tools usually warn you (and don't write the files) if a CRC error appears when unpacking.
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/03/13 - 21:13
With this version, I was able to flash using the supplied cable. Not sure if it is the version of the firmware or the cable. It works
63 Guest(s)
Devices in use: Desktop (57), Phone (6)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
