[ ROM ] Onda V973 (V2 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2 final (2013-07-03)
PrvSAT
Forum Posts: 25
2013/07/26 - 00:31
In fact it is not so very nice as mentioned... The wifi disconnects and can not connect again, it says "failed to connect". I have to do a reboot to connect again. What is happening?
If you do a hard reboot, it shows the Chinese lady forever. It is very disturbing!!! You should not put junk like that in releases for public. What was the logic?
How we can remove this completely inappropriate image?
2013/07/26 - 01:32
The Chinese lady as boot logo comes from the official release from Onda, not us; feel free to complain to the manufacturer. This image is just left in our release as our initial try to change it prevented the tablet to boot.
PrvSAT
Forum Posts: 25
2013/07/26 - 01:38
How is that possible unless the pictures has something specific embedded in it so that at boot is looking for.
But again, if this picture is set by Onda why does not appear at boot with the original f/w from Onda, the f/w that arrives with? Thank you for your reply.
What about the Wifi problem? Any fix soon or advice?
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
2013/07/26 - 08:27
"But again, if this picture is set by Onda why does not appear at boot with the original f/w from Onda, the f/w that arrives with? Thank you for your reply."
The picture of the Chinese lady were added by Onda in the last firmware release and if you load the latest stock Onda firmware, you will see them too.
Pingu
PrvSAT
Forum Posts: 25
2013/07/26 - 12:53
Here are my findings about this release. I hope to be wide issues so that the developer could fix these.
- WiFi is sometime intermittent. In the router, based on the tablet's MAC address I reserved an IP for it. I will see if this will improve the connection.
- The videos like music clips or movies with extension avi, mkv, mp4 are playing OK but the sound is terrible. This is when using headphones and expecting for the sound to be good. The files are OK and are used on other devices. I have tried this with 4K player and two others players, including VLC. It sounds like in a metal can and the voice is very week, something like it is a filter enabled and mid frequencies are cut completely.
Please report/confirm on this issue. Is it fixable?
The following users say thank you to PrvSAT for this useful post:
f0u
seek
Forum Posts: 11
2013/07/27 - 03:08
Hi all,
I don't be able to flash it via PhoenixSuite.....dunno if I'm a jackass or my pc with win7x64 have problems...Yell
So, there is a way to flash it via TWRP?
It 'a question of life or death....CryCryCry
Thanks all
Seek
ROM for Onda tablet (continuous updating): V971 - V972 - V973 - V975 - Phoenix Suite - Root tool - Hosted on my MEGA account compressed with 7zip
PrvSAT
Forum Posts: 25
2013/07/27 - 05:23
seek said
Hi all,
Thanks all
Seek
I found that using a motherboard installed USB did the trick (back of the PC). Quite possible that other USB's do not have the power required to the flash. This is what worked for me after I tried few times on different USB's.
seek
Forum Posts: 11
2013/07/27 - 12:24
Thanks PrvSAT
I have tried all USB ports of my notebook, but...nothing :'-(
Others suggestions?
Seek
PrvSAT
Forum Posts: 25
2013/07/27 - 12:51
I was in the point to quit with all upgrades after I tried to bring the fkn tablet in recovery mode. After I tried also the rear USB's, I said, I'll give it two more shots on another computer. This was a MAC loaded with Windows via Parallels. And it worked!
Going back to the 1st PC, I have uninstalled, rebooted, re-installed the Phoenix s/w and then it worked! (Go figure!). I had to re-write the f/w few times since I keep writing the wrong one (v1).
If your Phoenix s/w does not detect the tablet in regular mode with all USB drivers installed, then it will not work the above.
seek
Forum Posts: 11
2013/07/27 - 18:12
After a flash of the latest CM 10.1 via twrp, it stuck in boot logo!!!
But the TWRP can start...damn me...
I officially ask for help!
luking
Forum Posts: 26
2013/07/29 - 03:44
Wifi and poor sound quality are two main issues with stock v973
If they are present in this release then what is the point of trying this release? Are there any other advantages really?
nick789uk
Forum Posts: 45
2013/07/29 - 08:17
hi been using this rom for a while and never had a problem with the wifi also the sound is a heck of a lot better and loader both on the 4k player and on MX player which is really great on the sound. thanks uploader for a great rom.
PrvSAT
Forum Posts: 25
2013/07/31 - 16:31
So everything seemed to be OK, I finished the backup using Titanium purchased version and I was happy. Loaded some vids and I connected the tablet to the TV via micro HDMI. TV did not detected the cable and of course no image.
Then the WiFi disappeared (again). So I did a long reboot and then on black screen I get "Installer failed to start" and nothing. Waited for a minute, nothing happened. Powered down and done again a long reboot with the ugly on the screen but this time it stuck to the very first square picture of the CPU All winner and stays like that forever.
Tried again, shut down the power, insert the USB, detected, the CPU image appears but it is stuck to this image. WTF??? Did I just screwed this tablet?
I said once that I will not buy junk anymore and here I am. What is happening?
PrvSAT
Forum Posts: 25
2013/07/31 - 16:44
I had to load the f/w and start from zero. It sucks big time. Now it works.
So, what was it, the h/w or the s/w or both?
2013/08/03 - 17:05
47 Guest(s)
Devices in use: Desktop (41), Phone (6)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
