[ ROM ] Onda V973 (V2 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 (2013-07-29)
2013/08/03 - 17:04
Here is latest Android 4.2.2 Jelly Bean update for the Onda V973 tablet (hardware V2) based on newest Onda firmware release version 3.2.1 published 2013/07/29
(V973Core4_v3.2.1_v2.rar)
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 25 16:28:08 CST 2013
Android system: onda/fiber_onda974q963/fiber-onda974q963:4.2.2/JDQ39/20130726:eng/opinions-on-teclast-p90hdst-keys
Firmware version 3.2.1 revision history:
1, increase MIRACAST wireless display feature
2, optimize system performance
3, optimize tablet standby time
4, optimize HDMI TV output function, support 1080P input and Full Zoom
5, amended Chi reader does not recognize the local disk compatibility issues
6, amended in google play find Youku, and other parts of the application tuxiuxiu question
7, the amendment 4K player, vertical screen gestures invalid under the volume problem
  • root with latest SuperSU 1.51 (free version)
  • system default setup English
Download: kasty-onda_v973_v2-422-v321_20130729-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
PrvSAT, nick789uk, seek, ru.Egor, cardvr, sl33py
PrvSAT
Forum Posts: 25
2013/08/03 - 17:54
I am glad to see an improved version! Congrats for the hard work and thank you for this release.
There are some things that clearly are getting better and all these are wonderful features. I noticed that one thing is missing in the revision history: it seems that the Chinese girl still shows up on boot, is this correct?
I am not sure what is the history of this but perhaps this girl Onda, is someone's lover or daughter or something that the name itself not being sufficient and given the gap of neurones in this individual's brain, it was decided to be "admired" by all at boot up. How stupid is that, really?
rockrawler_1492
2013/08/03 - 18:45
If I have already flashed once with the version before this release, will I need to the full format or can I just do the update in the phoenix tutorial?
jim1119
Forum Posts: 11
2013/08/03 - 19:41
Just flashed and everything ok. The volume is now loud enough for me, the battery  indicator is no longer acting like an egg timer and the icons are moving between home screens a lot smoother. Thanks for this custom rom.
nick789uk
Forum Posts: 45
2013/08/03 - 22:17
Hi thanks for the new rom just flashed it everything appears fine and working great very responsive volume load still playing with it but again thanks.
drunja40
2013/08/04 - 07:47
Hi! when will it be available for V1 version? thank you)
seek
Forum Posts: 11
2013/08/05 - 11:23
Thanks for this ROM admin!
Did you still see the battery percentage indicator? Disappeared to me, but it can be maybe a problem of the stock.
S.
ROM for Onda tablet (continuous updating): V971 - V972 - V973 - V975 - Phoenix Suite - Root tool - Hosted on my MEGA account compressed with 7zip
PrvSAT
Forum Posts: 25
2013/08/05 - 15:51
S.
I just wanted to mention the same thing. It seems that this little and useful feature was left out.
2013/08/06 - 01:31
S.
This hasn't been touched, it probably wasn't there in the stock firmware.
seek
PrvSAT
Forum Posts: 25
2013/08/06 - 01:37
The previous release did show the battery percentage. I am sure because I used to check it all the time.
Katcha
2013/08/06 - 08:03
But the newest Onda firmware release version 3.2.1 published 2013/07/29 doesn´t have battery percentage indicator too.
Please - is it possible that the original Onda firmware version 3.2.1 has longer battery life than this Kasty´s 3.2.1 rooted??
seek
Forum Posts: 11
2013/08/06 - 09:08
Someone can send a report to Onda? ;-)
drunja40
2013/08/07 - 21:42
What about rooted firmware for V1 version? when wiil it be availible?
The following users say thank you to drunja40 for this useful post:
stefan_skellen
PrvSAT
Forum Posts: 25
2013/08/08 - 00:59
The HDMI feature could be found in settings but again, as the previous f/w when connecting a cable to a TV doesn't do anything. It is just an extra connector that could not be used for anything.
2013/08/09 - 12:39
For those familiar with TWRP Recovery and interested in testing it, I am looking for feedback on your Onda tablets. Please check and post your test results in this topic:
http://www.arctablet.com/blog/forum/onda-tablets/stable-twrp-2-6-6-0-now-working-for-kasty-onda-3-2-sdk-firmware/#p27695
69 Guest(s)
Devices in use: Desktop (60), Phone (9)
