Firmware build information:
Linux Kernel: Â Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 4 09:43:24 CST 2013
Android system:Â onda/fiber_onda974q9/fiber-onda974q9:4.2.2/JDQ39/20130704:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.41 (free version)
Download:Â kasty-onda_v973_v1-422-v32_20130704-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V973 (hardware V1) to test it.
RedWolfwere, bigcheek, psionara, djtwinz, jored1222, stefan_skellen, ricky88, ru.Egor, pescadorsp If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/05/31
grazie per il supporto per questo tablet dai requisiti fantastici ma poca ottimizzazione.. con il passare degli aggiornamenti diventa sempre migliore!!Â
sono curioso di vedere la differenza tra la versione 3.2 adattata dal v972 al v973 che monto ora  a quella per  v973 nativa scarico subito e posto le mie impressioni!!!
2013/03/10
francesco91bb said
I noticed that the wifi is very weak in this tablet .. there is not no way to be able to enhance or at least optimize?
I apologize for English but I use google traduction
You are not alone,
I also have a V972, and depite both having the latest 3.2 firmware, it's night and day.
V972: Fast stable wifi, butter smooth since 3.2.
V973: Weak slow wifi, laggy just like in 3.0 (yes I have completely reflashed with mandatory format).
I wonder if onda really have made some major change on the 3.2 for the V973 or if it's just a 3.0 with the quick boot...
2013/03/10
pas1970 said
Strange. I find the V973 really responsive now and the wifi a lot better.
I've got the latest stock firmware.Â
Let's say that they are indeed improvements over the 3.0 on both wifi and speed, but not as much as they were on the 972 from 3.0 to 3.2.
EDIT: I did a test with the V972 and V973 facing each over, the 972 feels about 10% faster in every task, touchscreen latency is lower, the 972 feels more reactive and less laggy, I wonder if onda have used lower quality flash chips on the 973?
For info my 972 is V2, and my 973 is V1.
2013/03/03
HI , I Need some help. The Kernel in this rom made my tablet not usable, the previews version of this rom was perfect! http://www.arctablet.com/blog/forum/onda-v972/onda-v972-v1-hardware-android-4-2-2-jelly-bean-root-custom-firmware-v3-2-final-2013-07-04/
Please can you help me to downgrade the Kernel ? I need some serious help because I tried everything!
81 Guest(s)
Devices in use: Desktop (70), Phone (10), Tablet (1)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
