Linux Kernel: Â Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 25 16:28:08 CST 2013
Android system:Â onda/fiber_onda974q9/fiber-onda974q9:4.2.2/JDQ39/20130726:eng/opinions-on-teclast-p90hdst-keys
2, optimize system performanceÂ
3, optimize tablet standby timeÂ
4, optimize HDMI TV output function, support 1080P input and Full ZoomÂ
5, amended Chi reader does not recognize the local disk compatibility issuesÂ
6, amended in google play find Youku, and other parts of the application tuxiuxiu questionÂ
7, the amendment 4K player, vertical screen gestures invalid under the volume problem
- root with latest SuperSU 1.51 (free version)
Download:Â kasty-onda_v973_v1-422-v321_20130729-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
stefan_skellen, drunja40, ricky88, ultrawires, Balrog, XGU, RedWolfwere, chinesetown, mangmoo, lameer If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/02/10
Installed as fresh install. Tablet boots up and then is unresponsive from unlock screen. Orientation is unstable, screen flips to upside down immediately. Unable to get to settings. Uninstalled to previous v3.2.1_v1. Anyone else having similar issues?
Three attempts with 2 downloads of firmware from above.
2013/06/01
lahdee said
Installed as fresh install. Tablet boots up and then is unresponsive from unlock screen. Orientation is unstable, screen flips to upside down immediately. Unable to get to settings. Uninstalled to previous v3.2.1_v1. Anyone else having similar issues?Three attempts with 2 downloads of firmware from above.
My touch is flipped right to left and orientation sensor is upside down.Â
It could be that the firmware you flashed doesn't correspond to your tablet model or hardware version, please double check to make sure your flashed the right firmware. You can also try flashing the V973 firmware for hardware V2, it happen on other models that the hardware version on the tablet was incorrectly labeled.
2013/06/01
My serial nr. is: SN:V972QAD3V1A01480
2013/05/17
tester12as said
It could be that the firmware you flashed doesn't correspond to your tablet model or hardware version, please double check to make sure your flashed the right firmware. You can also try flashing the V973 firmware for hardware V2, it happen on other models that the hardware version on the tablet was incorrectly labeled.My serial nr. is: SN:V972QAD3V1A01480
This thread is V973.
You should try this...http://www.arctablet.com/blog/forum/onda-v972/onda-v972-v1-hardware-android-4-2-2-jelly-bean-root-custom-firmware-v3-2-1-final-2013-07-26/
2013/06/01
Of course, sorry i didn't noticed that, and sorry for wasting every ones time.Â
The firmware from post #1 is made to be flashed thru PhoenixSuit, it can't be used with the local update option.
Maybe try a PC/Windows Virtual Machine on your Ubuntu, I think a Mac user had some success flashing on his computer with a Windows emulator.
ozanbilgin If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/02/10
Downloaded v1 and reflashed. Looks like user error. Thanks Admin, you're work is appreciated. Send some paypal love
Currently Online: portvein
79 Guest(s)
Devices in use: Desktop (65), Phone (15)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
