[ ROM ] Onda V973 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.0 (2013-05-23)
baz159
2013/05/28 - 14:16
Thanks very much fabrav64 ill give it a go.
Thanks Received: 3170
2013/05/28 - 14:18
I'm interested in the outcome.
If it's all working fine, I'll eventually have this built in next custom firmware build.
frank997
robyrav68
2013/05/28 - 21:58
I made the same modification to the /system/build.prop file as suggested by fabrav64 on my V972 (V1 hardware) and it works very well.
So, thank you to fabrav64 and of course to admin for the great effort to cook the kasty ROM for the comunity.
Night
f0u
2013/05/29 - 00:50
Thanks Admin!!
But a question regarding this rom, is the tablet och the roms fault . that it feels very sluggish. Micro lags in menus and take ages to render a webpage and so on ..
Tried a couple of other china tablet's and there all felt really faster in everything. Compared to Onda v973
baz159
2013/05/29 - 14:33
This change works well.
Ability to add users now.
Just press add user, the tablet restarts then has another user on the front screen.
Any apps you want the user to have just download from play store again and it will just install them on their screens.
Thanks.
Donkman
2013/05/29 - 14:42
Works great on mine also! Onda 972 V1 with lalest Kasty ver. Thanks fabrav64! Smile
chittu
2013/06/01 - 12:18
works well, but got issue wifi, it doesn't show available network, but works fine when I entered ssid manually. I had the same issue with the original 4.2.2 but it was very fine with 4.1.2 (was showing all available network).
Doesn't anyone have the same issue here?
nlandin
2013/06/01 - 16:45
Works great, very fast and snappy.
Just out of curiosity; does anyone have access to Miracast / Wireless Display setting (usually in the display settings menu)?
I don't know if it's listed in the original 4.2.2 version, but I can't seem to find it in my tablet. Confused
2013/06/01 - 16:47
I don't recall ever seeing it on a V972 firmware, I don't think the feature exists for now... unfortunately Confused
nlandin
ricky88
Forum Posts: 17
2013/06/01 - 17:15
Hi guys, I have flashed this rom to my onda and its awesome, thank you so much!
I would like to change the boot logos however (not animation), can someone please tell me how, I would really appreciate it.
Thanks!
nlandin
2013/06/02 - 13:30
The Miracast feature might be in enabled in the near future I believe (or hope ;-) .
AllwinnerTechnology posted this 5 days ago:
CoolLaugh
stuedub
2013/06/03 - 18:41
Hey. Is there an English version of Phoenix Suite as shown in the instructions?
I'm struggling with the chinese version.
EDIT: For some reason, I started Phoenix Suite and it's in English.
Installed the custom rom. I must say, it's great. Very snappy. Chrome actually works properly now. Haven't had a proper play of it but first impressions say it'll be fantastic.
Thanks.
pas1970
Forum Posts: 21
2013/06/06 - 13:05
Hi
My first post on this site. Looks like there's a lot of great info.
I've got a V973 which I bought in Shenzhen on a recept trip. Been having all the frustration it looks like others are having.
After I upped to 4.2.2 it was certainly better, but still incredibly frustrating.
Somebody on this site on another tread talked about disabling the Chinese apps. I tried that and it sees way faster since that point. Anybody else seen this? It also seems more stable. Way less 'wait' messages.
For me the V973 seems like potentially a great device , for the price, but I've been pulling my hair out because of the stability.
bolp
2013/06/17 - 16:08
Hi There, thanks for posting the new version.
does anybody face a problem with skype audio? I'm not able to hear people when they call me...
RedWolfwere
Forum Posts: 21
2013/06/18 - 09:50
tried Skype twice and no problem.
Anyway, i' experiencing the usual sluggish in typing with the keyboard and browsing web; anyone has same experience as me?
67 Guest(s)
Devices in use: Desktop (58), Phone (9)
Cellarin
kuzin
Dag58
montolla
portvein
POELE
