2013/07/22
Hey, guys.
I bought this tablet 2 months ago, and I was as happy as Droopy, until I connected to a TV by HDMIÂ cable yesterday.There is no any changes on the tablet screen, the TV can not detect device on an HDMI port.
I tested it with previous ROM - no result.
HDMI cable is tested with Asus tablet and it is 100% fit.
Could you please help me with this issue?
Thanks in advance.
Please have a look here:
http://www.arctablet.com/blog/forum/onda-v972/hdmi-in-onda-v973/
2013/04/15
Hello ondauser,
you need to also cut back the harder plastic that is closest to/around the metal part.
It looks to me like the part still won't go in any deeper as it is. I had to do this with my v813.
I also had to cut out the case around the HDMI socket to allow even further entry.
Finally it worked! it is simply a case of no electrical contact.
The fact that the sides of the tablet are curved is the problem. The onda USB charging cable has an extra long metal part to overcome this.
yes, generally crap design.
Pingu
2013/04/15
On your picture, it looks to me like the plastic bits on the sides/edges (see arrows in picture) will stop it going in in the same way as before.
I also had to cut the side of the case a little to allow deeper contact.
The Onda supplied USB charging cable is longer than a normal one but it seems that an HDMI cable like this is more difficult to find.
Of course, the USB cable came direct from Onda with the tablet. They do not seem to sell HDMI cables in their accessories.
http://www.onda.cn/Tablet/ProductList.aspx?ProductTypeId=88006&SerialId=98005
I got my tablet from onda-tablet.com which is just a reseller for the English speaking market. They do not sell an HDMI cable of the correct size or length either. The HDMI cable I got from eBay.
Pingu
Currently Online: floki
97 Guest(s)
Devices in use: Desktop (88), Phone (10)
floki
orocamora
Ellocojoe
Tonysc17
olegator
Ur
