2013/04/29
even with an update to firmware 2 ,wifi connection will drop off after awhile. have try 2-3 times to reconnect-sometimes says not in range(2 feet from router). Much better after the upgrade but still problematic. Anyone else having this problem and ideas for solving problem. Was awful with out the upgrade almost impossible to connect at all. But no other tablets or phones having this issue.Thanks
2013/06/11
Ditto here.
I am at 1.32 and I have tried many recommendations with no success.
- Changing from WPA to WEP - no change
- Changing Mhz on which wifi router adversities - no change
At the moment I cannot even coax in online. Normally after 15 minutes of fiddling it connects; but not this time. Always out of range, even though it is < 1 foot away.
2013/06/11
That is what I meant above by - Changing Mhz on which wifi router adversities – no change
So, after some looking around, it appears that freeing the physical antenna internally from its original location has had the best luck.
Does anyone know the type and size of wrench needed? It looks like a tiny hex or torx but my feeble eyes cannot see...
Thanks in advance,
L
100 Guest(s)
Devices in use: Desktop (89), Phone (11)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
