[ ROM ] Onda V972 (V2 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2 final (2013-07-04)
2013/07/05 - 18:53
Here is latest Android 4.2.2 Jelly Bean update for the Onda V972 tablet (hardware V2) based on newest Onda firmware release version 3.2 dated 2013/07/04. This firmware actually uses the same version number as previous Onda release, but the build dates for kernel and Android system are more recent. It's very possible that previous firmware released in June was a pre-release and this new 3.2 is a final release.
Compared to firmware version 3.0 or older, this update brings many enhancements such as a faster boot (5 seconds !) smoother system and a reduced power consumption in stand-by mode.
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 4 09:43:24 CST 2013
Android system: onda/fiber_onda978q9p6/fiber-onda978q9p6:4.2.2/JDQ39/20130704:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU 1.41 (free version)
  • system default setup English
Download: kasty-onda_v972_v2-422-v32_20130704-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V972 (hardware V2) to test it.
Thanks corollo for his support
ru.Egor, Larision
lolxdptrd
Forum Posts: 24
Thanks Received: 6
2013/07/06 - 09:15
The fuck with the new bootscreen?
NOPE NOPE NOPE
Rolling back to the june version. :)
Or maybe you can rebuild this one with the old "since 1989/arctablet branded" bootscreen/booanimation from the june version?
The following users say thank you to lolxdptrd for this useful post:
Larision
corollo
2013/07/06 - 12:45
Thank you,
for the good work.
lolxdptrd
Forum Posts: 24
Thanks Received: 6
2013/07/07 - 11:22
I haver been playing with this firmware a little more despite the horrible new boot picture.
I haven't found any differences in term of smoothness, etc... I really think this new firmware is just there to put the new pictures on startup (Onda have a partnership with this girl? maybe a model from china?).
Anyway, back to the june version, and I'm going to keep it until the next allwinner sdk update (august/september maybe).
johan1914
2013/07/07 - 17:39
Halo Admin,
thanks for your hard work. I've been install and run smooth. but I found  problem with my camera. it does't work.why? can you give me advice?
thank you so much.
Philosopheur
Forum Posts: 16
2013/07/09 - 13:42
Onda V972 v2
I have finished installing Kasty ROM 422 v3.2 (2013/07/03) with Christian Troy's recovery TRWP 2.6.0.0.
Every Thing is ok.
Thanks Admin,
Tablette ONDA V972-v2 ROM STOCK 422 Root
javigs
Madrid
2013/07/15 - 00:21
Amazing! I have just bought this tablet (Onda V972 v2) y only I have installed this custom room with PhoneixSuit (on this forum too) and the change is incredible.
Thank you, thank you so much.
EDIT: How do i do to make a capture of screen? Thanks
PrvSAT
Forum Posts: 25
2013/07/25 - 15:25
Sorry, looking for V973 release.
stevieo63
2013/07/31 - 03:14
I've recently updated to 4.2.2 using the file that Onda provided me and Phoenix Suit. (I agree the new boot screen needs to go!)
my device is the onda V972  v2
my firmware is  now  v2.3_v2
kernal version is 3.3.0.
build number is fiber-onda978q9p6-eng 4.2.2 JDQ39 20130704 test-keys.
The tablet isn't rooted anymore.
I've watched your tutorial on rooting it, and i've checked with the root checker app which now says I am in fact no longer rooted.  Is the rooted zip file (http://www.arctablet.com/blog/featured/root-onda-v812-onda-v972-and-allwinner-a31-based-tablets/) only good for v1?  I have a v2; do you have a root zip file for that?
if not....
What file do i need to re-root it?  Is it the kasty file listed above?  Is the kasty file the entire android .img file that's just rooted?
Thanks for the help.
Philosopheur
Forum Posts: 16
2013/08/08 - 18:37
Please Admin the new version 3.2.1 for v972 v2
The following users say thank you to Philosopheur for this useful post:
blodnje
2013/08/09 - 19:30
73 Guest(s)
Devices in use: Desktop (64), Phone (9)
