[ ROM ] Onda V972 (V2 hardware) Android 4.2.2 Jelly Bean root custom firmware v2.3 beta (2013-04-23)
Thanks Received: 3170
2013/04/28 - 02:29
clchong84 said
hi morning
after in flashg V2.3 firmware, when i install CWM on arctool cannot reboot recovey.
any solution
thanks you
CWM Recovery currently doesn't work with latest firmwares such as V2.3, because of a different partition layout. We'll post when we find a fix.
daninkk
clchong84
2013/04/28 - 03:07
hi morning
after in flash to V2.3 firmware, when i install CWM on arctool cannot reboot recovey.
any solution
thanks you
Access
2013/04/30 - 18:05
i tried this ROM now for some ours and experienced quite a few problems:
- Camera is unable to start ("Camera Error: Can't connect to the camera.")
- A few Settings are unable to access, for example Users->Owner or Display->Daydream->Clock Settings ("Unfortunately, Settings has stopped").
I tried the v1 ROM as well, where the camera is usable, but here the tablet froze a couple of times under different circumstances. Once while browsing another time while i was searching the google market, a third time while looking through the settings. In this case i had to hold the power Button because it didn't react to any input.
Now I am trying the V2 ROM again and will tell you if the tablet freezes as well.
hdonk
2013/05/01 - 10:09
I've been trying this version of the FW (V1 & V2), but have a problem... When I reinstall my backup data, at some point the /data partition gets corrupted. I've tried it several times, and it only seems to happen after a particular installed amount.
Anyone else seen anything similar? The symptom shown is the table is stuck permanently in the boot animation.
I'm wondering if I've got bad nand, or there's just a problem with the FW.
tiner
2013/05/01 - 12:53
Hello everybody,
Just tested this rom for two days. It is very smooth so the apps are opening fast too.
Nevertheless, there are a few mistakes a bit annoying for me.
After using it for two days or after the first reboot (don't really know exactly why), CRT effect and transition effects between main desk and app menu, disappear.
What about you?
osirius.eu
2013/05/09 - 08:28
I experiense the exact same problem. I manage to recover (not the applications) by holding both buttons for 30-40 seconds until the Green android appears and i wipe the cache.
I have done this at least 4 times and i am moving back to 2.0 version.
Other issues.
Auto rotate Option --> When you disable the auto rotate option then the screen rotates back to Original position (with buttons on the left) the previous version was locking the screen to curent rotation (i like it with buttons on the right)
Battery options --> are gone. While on previous version i could see the battery consumption with this version it is not supported
I am new to tablets and this is my first one.
So i would like to ask how can i have this bottom bar also in v2.0 ?
My hardware is a v2
hdonk
2013/05/09 - 10:13
Other issues.
My hardware is a v2
Other issues.
My hardware is a v2
I'm glad I'm not the only one who's had this! I've reported the problem to Onda. I suspect it's because in the new FW they've updated the partition table so there's just one for the system & data.
Choronzon
2013/05/12 - 01:26
Antioch, thanks for the observation regarding possible V1's labeled as V2 hardware. Pretty sure mine is a V1 as my camera stopped working, after V2 update. I will update with V1 firmware.
77 Guest(s)
Devices in use: Desktop (73), Phone (4)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
