[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2 final (2013-07-04)
Bondo2
Forum Posts: 44
Thanks Received: 4
76
2013/07/31 - 23:01
santolito said
Bondo2 said
santolito said
Well, I downloaded and installed the new "V972Core4_v3.2.1_v1" rom. It behaves pretty much the same in performance compared to the previous rom. One of the new things I noticed is that there are some new options in the settings that I did not see in the previous version. Also, there's this photo of a cute Chinese woman in a white dress that's part of the boot up screen. But the one major thing I can attest to, is that this time around the battery holds it's charge a lot longer! that's right, the battery last longer! None of that rapid countdown drop on battery juice, now it lasts as long as it used to when the Onda 972 tablet first came out on the market.  With that said, I am still having some WiFi dropout issues, but I can still get around that by using the "Best WiFi Keeper PRO" app to help me alleviate that problem.
Can you tell how long the battery lasts now ?
Well, I have not really measured properly the time from a fully charged battery, but I can tell you that after upgrading to the new rom I had about a 72% battery charge level when I started to surf the web for about 1 hour and afterwards play a couple of 3D graphical intensive games for another 1 1/2 hours  before the battery charge dropped to about 35%.
This means 2.5 hours for 37% which seems too much as this means more than 6 hours . I am using now CM10.1 and am doing almost 4 hours of Internet browsing (Firefox) and this is based on 3.2 firmware.
Can you do us a favor and try a real test from 100 to 50% ?
billkaroly
Forum Posts: 61
Thanks Received: 6
77
2013/08/01 - 02:57
Does Admin plan on a Kasty version of 3.2.1?
msav
Forum Posts: 71
Thanks Received: 13
78
2013/08/01 - 15:59
It is great that onda is now focused improving the battery life.
I will wait patiently for Admin to release Kasty 3.2.1
RedWolfwere
Forum Posts: 21
79
2013/08/01 - 16:53
I've tested the airplane feature while on Wi-Fi with this release of the rom (v3.2); sincerily looks like the battery performs the same as usual.
What about Miracast feature? its necessary a software ?
Thanks Received: 3170
80
2013/08/01 - 20:37
I have just posted a new firmware for the Onda V972 (v1) based on latest Onda update v 3.2.1:
http://www.arctablet.com/blog/forum/onda-v972/onda-v972-v1-hardware-android-4-2-2-jelly-bean-root-custom-firmware-v3-2-1-final-2013-07-26/
kontra.sz, billkaroly, bazk123, bhabes1954
bazk123
London
Forum Posts: 51
Thanks Received: 5
81
2013/08/02 - 12:15
Will be trying this one after work tonight, thanks Admin :)
billkaroly
Forum Posts: 61
Thanks Received: 6
82
2013/08/06 - 18:56
Official 3.2 - Unfortunately UIDs have become inconsistent
My wife's 972 is giving her this message whenever she powers it on. Never got this on previous versions. Moving her to 3.2.1 now.
Yuptizme
83
2014/05/11 - 11:27
Hi all,
I'm new to this forum and I note it's a while since anything was posted here.  I have a V972 V1 which I flashed with this update however my camera has failed.  I note that others have this experience and was wondering if anyone managed to find a fix.
91 Guest(s)
Devices in use: Desktop (78), Phone (13)
jomama
biggfafa
himikus300483
CyberByte
printerr724
KarlCharlson
