[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2 final (2013-07-04)
2013/07/04 - 19:18
Here is latest Android 4.2.2 Jelly Bean update for the Onda V972 tablet (hardware V1) based on newest Onda firmware release version 3.2 dated 2013/07/04. This firmware actually uses the same version number as previous Onda release, but the build dates for kernel and Android system are more recent. It's very possible that previous firmware released in June was a pre-release and this new 3.2 is a final release.
Compared to firmware version 3.0 or older, this update brings many enhancements such as a faster boot (5 seconds !) smoother system and a reduced power consumption in stand-by mode.
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 4 09:43:24 CST 2013
Android system: onda/fiber_onda978q9/fiber-onda978q9:4.2.2/JDQ39/20130704:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU 1.34 (free version)
  • system default setup English
Download: kasty-onda_v972_v1-422-v32_20130704-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
This custom firmware has been tested and reported to work on the Onda V972 tablet (hardware V1 model)
eKICh, billkaroly, eric90, wisconsin, BG99, jored1222, perstrom, PiPi, nellslasher, avcpl, erictanyh, bmarkman, tschaep, mostafa2207, nalla0726
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/07/04 - 21:28
Download: kasty-onda_v972_v1-422-v32_20130704-rooted.zip
This custom firmware has not yet been tested on the Onda V972 tablet (hardware V1 model)
Downloaded and tried to install but get an error message. It says 3% and then the bar moves quickly and bam! Error message. Maybe my download was corrupted so I am re-downloading it.
The following users say thank you to billkaroly for this useful post:
XGU, nalla0726
Alban1
Forum Posts: 14
Thanks Received: 4
2013/07/04 - 21:31
Tried to flash this using Phoenix but each time I got error message"EODESus" at around 15% progress.
Successfully reflashed previous Kasty version to my Onda 972 v1.
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/07/04 - 21:32
I got the same.
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/07/04 - 21:40
Looks like a corrupted upload
johnny2dd
2013/07/04 - 21:43
dont work for me either.
delux
2013/07/04 - 21:51
I have the same 3% and error
2013/07/04 - 22:02
Thanks for your feedback and sorry about this issue.
I don't think it's a corrupted file problem, as we do check file integrity for all uploads.
I'll have a look if I can find any changes Onda made between the two firmwares. In the meantime, I'm removing the download.
conbodyact
2013/07/04 - 22:22
Damnnnnnnn, I'm bricked!!!!!!
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/07/04 - 22:32
I thought maybe I was as well but I was able to install a previous version without disconnecting from the PC.
1. While USB is still attached hold down the power button until you hear the PC sound the disconnect.
2. Select the firmware file in PhoenixSuit.
3. Hold the power button until you hear it reconnect.
It should start installing at that point.
conbodyact
conbodyact
2013/07/04 - 22:36
thnks a lot!!!!!!!!! :-) ))))))
jim1119
Forum Posts: 11
2013/07/04 - 22:37
I thought I was after trying to flash this new rom. I pressed and held the power button for 10 seconds then flashed the previous 3.2 rom in the usual way and it is working again . Good  luck.
The following users say thank you to jim1119 for this useful post:
conbodyact
Alban1
Forum Posts: 14
Thanks Received: 4
2013/07/04 - 22:47
The new firmware  http://pan.baidu.com/share/home?uk=389436537 -  2013-07004 flashed ok without any errors in Phoenix.
conbodyact
2013/07/04 - 22:51
is the new kasty rom?
Alban1
Forum Posts: 14
Thanks Received: 4
2013/07/04 - 22:53
no.  The stock rom with all the Chinese apps.
107 Guest(s)
Devices in use: Desktop (88), Phone (19)
hans41
rickybk
soniya07
ironmangitar
