[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2 (2013-06-21)
2013/06/25 - 14:12
Here is a new Android 4.2.2 Jelly Bean update for the Onda V972 tablet (hardware V1) based on latest Onda firmware release version 3.2. This update brings many enhancements such as a faster boot (5 seconds !) smoother system and a reduced power consumption in stand-by mode.
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Tue Jun 18 12:27:17 CST 2013
Android system: onda/fiber_onda978q9/fiber-onda978q9:4.2.2/JDQ39/20130621:eng/opinions-on-teclast-p90hdst-keys
Onda_V972_V1_firmware_3_2_about.pngImage Enlarger
  • root with latest SuperSU 1.34 (free version)
  • system default setup English
Download: kasty-onda_v972_v1-422-v32_20130621-rooted.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
This custom firmware was tested and confirmed to work on the Onda V972 tablet (hardware V1 model)
crashito, Donkman, bazk123, kenghua, stonehill, juve17, avcpl, lurker415, aryanitinkumar, buzz360, btongkm, groundhogman, eKICh, erictanyh, notabot, nellslasher, turion64, jored1222, lahdee, frank997, Auriga, heurikas, adanteny, bhabes1954
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/06/25 - 14:27
Why does it say 21/6 ?, I thought it was released today
The following users say thank you to Bondo2 for this useful post:
Donkman
2013/06/25 - 14:30
I usually put release date with the most recent item from either the kernel and Android system, "20130621" in the case of that firmware. Onda probably took some days to validate their firmware before making it public, which could explain the delay.
I find this dating method more reliable than using the file upload date, as it can be re-uploaded at different places/times.
PiPi
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/06/25 - 14:32
Are you sure they haven't changed anything in between ?
2013/06/25 - 14:37
I can't be sure of anything, the firmware file used to build the custom firmware was downloaded today.
TabletUser
2013/06/25 - 14:42
famimon
Forum Posts: 20
2013/06/25 - 17:37
The previous version drained out the battery in no time, have you noticed any improvement in this one?
btongkm
2013/06/25 - 19:10
It is fast and fixed all my apps issue with v3.0. I love it.  However, none of the recovery CWM, TWRP for 4.2.0/4.2.2 work for my v972 v1. I just cannot run any backup. Tried them all already, my device just wouldn't reboot and hanged at A31 logo displayed. I have to reload the v3.2 firmware to get it boot again.
richleahy
Forum Posts: 11
Thanks Received: 4
2013/06/25 - 21:23
Hi admin,
Great work once again. Do you have a 'how-to' guide anywhere for editing and re-packaging these .img files i.e. what software do you use?
richleahy
Forum Posts: 11
Thanks Received: 4
2013/06/25 - 22:21
This version of TWRP works for me:
http://forum.xda-developers.com/showthread.php?t=2210676
lurker415
2013/06/26 - 04:52
Sorry, I'm sure this is an embarrassingly basic question, but could someone explain if there is a way to avoid having to reload all of my apps each time I update to a new version of the firmware?  Each time I've updated, it has wiped out everything, and I have to go back and set it all up.
kenghua
Forum Posts: 15
Thanks Received: 4
2013/06/26 - 08:20
This is the best update I had so far. Everything works for me. Thanks a lot.
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/06/26 - 09:13
Install Titanium backup and backup your apss+settings on an SD card and after you reinstall a new firmware use the TB to restore the apps.
richleahy
Forum Posts: 11
Thanks Received: 4
2013/06/26 - 10:57
Actually, sorry, loads of apps crash on boot up when I flash this version of TWRP so guess it doesn't work after all :( hope there's a version of TWRP that supports 3.2 firmware soon
The following users say thank you to richleahy for this useful post:
kenghua, btongkm
skippie
Forum Posts: 17
2013/06/26 - 18:54
SUPER!!!!! Charging whilst using the tablet!!!!!!!!!!!!!
Very smooth, this is getting better and better.
51 Guest(s)
Devices in use: Desktop (42), Phone (9)
