No 3.3 update is available for the Onda V972 so farÂ
We rely on Onda updates to rebuild a new custom firmware. It may be possible to reuse a firmware from other devices and mix it with an existing V972 firmware, but probably not worth the trouble as there is no guarantee is would work properly.Â
lagoonlife If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/11/11
Hi Guys,
I am having a horrendous time trying to update my Onda 972.
Firstly, no idea what version i have.
Secondly, I can only install from a SD card as i can't get any flashing programs to work, PhoenixSuit says WinUSB fail and doesn't see my tablet.
The only ROM that i have found that installs is cm-10.2-20131116-UNOFFICIAL-spark but the touch screen doesn't work once booted up so is useless.
I have tried every ROM i can find but they are either .img files (so can't install) or when i put it on an SD card the tablet doesn't see it as a ROM so i can't install.
Any help anyone can give i would be really grateful.
2013/03/09
Oberoth said
Hi Guys,
You can get the version number from the serial on the back of the tablet, look at Vn (where n is 1 or 2)
Do not use Windows 8 or Windows 7 64 bit while flashing the tablet with phoenix, usually it doesn't work
The ROM you mentioned is CyanogenMod (CM) and you should read its forum to understand how to flash it on Onda since it was developed for Ainol Spark (and hence the spark in the file name)
2013/03/04
The version of the tablet is written in its serial number on the back cover. If you see a v1 in the serial number then its version 1.Â
If you have problems with winusb then either your usb hardware is broken, you have viruses on your pc or you're missing your winusb.dll. Search google for fixing winusb problem.
and don't forget to read through this tutorial before flashing:
http://www.arctablet.com/blog/featured/phoenixsuit-flashing-tutorial-onda-v972-v812-allwinner-a31-tablets/
2013/03/15
New firmware version on Official site
Version 3.3.1
http://onda.cn/Tablet/ProductInfo.aspx?ProductId=239&d=down
1 new boot logo
2 new desktop systems Onda
3. The underlying SDK upgrades, system stability and compatibility enhancements
4.Miracast function optimization
5 The system comes with software adds multi-language support
6 fixes for known software problems
7 Set - New built-in storage under the total disk capacity display
(from google translate)
I'm currently working on making a custom firmware update with firmwre 3.3.1
I found the new Onda launcher not very convenient for non Asian users and I am considering to put back previous launcher, what do you guys think ?
2013/04/07
I'm currently working on making a custom firmware update with firmwre 3.3.1I found the new Onda launcher not very convenient for non Asian users and I am considering to put back previous launcher, what do you guys think ?
Mary be it would be interesting to have android default browser as default and this onda browser as an option. If the browser is installed in app space it can be uninstalled.
Anyway, thanks for the amazing work on this releases.
2013/10/31
Thank you for working on Kasty 3.3.1 so quickly! Â I have a v972 v2 tab and your ROM makes it much better. Â I use Nova Launcher so usually freeze (TitaniumBackUp) stock launcher anyway. Â
Thank you for your work! I plan to donate to support it when you release 3.3.1 (especially if there are no Chinese models in the boot animation hahaah)
kuma
Latest Onda V972 (hardware V1) firmware is here:
Download link is listed in post #1.
Other firmware downloads for the Onda V972:
http://www.arctablet.com/blog/forum/onda-v972/
95 Guest(s)
Devices in use: Desktop (86), Phone (9)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
