[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 final (2013-07-29)
renato0134
Forum Posts: 14
61
2013/10/31 - 11:15
Thanks for the advice but unfortunately it didn't work.
renato0134
Forum Posts: 14
62
2013/10/31 - 13:48
So i just installed the version v3.0_v1 and it works. i see all the internal memory.
v3.2 and v3.2.1 does not work. why?
l_themis
Forum Posts: 22
63
2013/10/31 - 15:38
After I install the latest version (I get the success message), the screen in not turn on and the tablet is dead!
I try to install the stock version but I have the same result. Please any sugestion?
neuokami
64
2013/11/01 - 05:05
Power consumption is the same, doesn't make any differences between the genius version.
4kplayer playing 1080p videos continously lasts 3 hours sharp ,battery goes from 98% down to 7%, at the lowest brightness and mute.
Cpu frequence is modified to 120/1008 by SETCPU.
I will test v2.0 and v1.35 for comparison later.
neuokami
65
2013/11/01 - 05:09
Thanks Received: 3170
66
2013/11/06 - 21:37
Guys, just to let you know, I have updated our custom firmware, see post #1.
By popular demand, the Chinese girl boot logos have been removed. Some kernel modules support have been added mainly for OpenVPN and gaming (XBOX360, PS3 gamepads)
Custom firmware update from 2013/11/06:
Kottur, bunch
bogg
67
2013/11/06 - 21:58
  nice to see some updates brought into this latest Firmware. I was wondering, is it possible to update to this new version without having to reinstall all my applications in the process ?
  Also, you integrated the Gamepad modules directly in the firmware but which Gamepads should now be working directly ? I followed the steps explained here in the forum to install the modules necessary and had to tweek it to use my Xbox 360 Wireless gamepad which uses a different code than the wired version.
  Thanx for letting me know and thanx for your updates, really appreciated  ;D
68
2013/11/06 - 22:05
Unfortunately, you'll have to fully reflash the firmware and reinstall your apps if you want to use the new features we've added. Xbox 360 Wireless gamepad is supported, I just enjoyed a Riptide GP2 game with it Wink
RedWolfwere
Forum Posts: 21
69
2013/11/06 - 23:20
Admin, its possible to have the same update for the Onda V973 v1?
Thanks alot for your patience and support!
l_themis
Forum Posts: 22
70
2013/11/07 - 13:09
Can I use this firmware to Onda v971 as it has the same specifications except the back camera?
71
2013/11/07 - 13:48
Unfortunately it's not recommended, each firmware is specific to a device. Using a V972v1 firmware on a V971 you would probably run into some problems with tablet stability or non functioning hardware components (camera, display, accelerometer...)
I'll see if I can update the firmware for V971 model as well.
l_themis
l_themis
Forum Posts: 22
72
2013/11/07 - 15:11
It will be great if you do it! Thanks in advance.
ron48383
73
2013/11/13 - 20:51
Hi Admin,
Thanks for all that you do.  Was just wondering if there will be an update to version 3.3 for the V972 v1?
msav
Forum Posts: 71
Thanks Received: 13
74
2013/11/13 - 21:05
I don't believe Onda has released 3.3 for the v972
ron48383
75
2013/11/13 - 21:40
I saw that the V975 got it and wondered if it would be released to the earlier devices as well.
85 Guest(s)
Devices in use: Desktop (76), Phone (9)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
