[ ROM ] Onda V972 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 final (2013-07-29)
adrianomm
Forum Posts: 11
2013/08/05 - 06:09
I tested battery performance playing 720p videos over WiFi. I used max. brightness, max. volume and HW decoding on MXPlayer.
My tablet, using this firmware, lasts about 3h30min playing videos nonstop from 100% to low battery shutdown. It was strange that the last 3~4% took a lot longer to go down.
It was better than the last firmware, but only by ~20 minutes.
The tablet is definitely better with this new firmware. May be if I set CPU Governor to "On demand" and minimum frequency to a lower value it will be possible to improve battery performance even further. I will test that...
The following users say thank you to adrianomm for this useful post:
jored1222
maildr
2013/08/06 - 21:47
Will there be a V2 hardware version?
Thanks Received: 3170
2013/08/06 - 21:48
Sure, will do it when time permits.
josedb
2013/08/08 - 05:25
I dont think better cpu management will improve battery life because primary battery leech is the screen, this problem is present in all tablets with this screen resolution... even the ipad3. We better get used to this battery life, or we move to lower resolution such as x768 , or x1080.
cheers
2013/08/09 - 12:39
For those familiar with TWRP Recovery and interested in testing it, I am looking for feedback on your Onda tablets. Please check and post your test results in this topic:
http://www.arctablet.com/blog/forum/onda-tablets/stable-twrp-2-6-6-0-now-working-for-kasty-onda-3-2-sdk-firmware/#p27695
Bondo2
Forum Posts: 44
Thanks Received: 4
2013/08/09 - 15:29
I already have TWRP on my V972 and working fine and used for several backups and restores
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/08/09 - 18:11
Package File Error
My wife has a lot of games installed on her tablet and some will not install on version 3.2.1. She gets an invalid package file error. There are several that will not install and I have tried them on both of our tablets.
I am thinking it's a Play Store problem because Save The Puppies (one of the games) will not install on my Nexus 4 either. It does install from the Amazon App store.
bhall109
2013/08/12 - 01:35
works great other than the soundcloud app im getting a playback error
FunThomas76
2013/08/14 - 20:40
Is it normal when using the tablet as mass storage device under windows it is only allowed to write to internal SD and not to write to external SD ?
blodnje
Forum Posts: 13
2013/08/18 - 08:00
Anyone experience random crashes on 3.2.1 ? In general this version is O.K., fast, decent battery drain, fast boot ... I did reflash, erase cache, factory reset. Before and after. No help. I never had that many stability issues as with this one. I do regular updates since 1.3.
I am using Holo launcher instead stock.
Also:
Google maps always force close
dabirn1308
2013/08/18 - 13:33
Google Maps always force close since ltest update. Google PlayMusic and AmazonMP3 both don't legt me prelisten to Songs in the shop.
NicholasMora
2013/08/18 - 13:34
Hey.
Google Maps dont work, especially the new version 7. It crashes constantly. You can side-load an older version like 6.7 and it will work. At least it did for me. But be careful with automatic updates then ;)
I have a feeling that 3.2 final was better. A lot of crashes and unexplainable behavior (slow, unresponsive,...) with this ROM. Battery drainage is the same I think - not really a noticeable difference. But I think if you put it in flight mode and then turn on wifi, battery lasts longer. I charge every three days and I play with it for an hour and a half a day.
sassouki
2013/08/21 - 07:29
Hello, i intalled the fireware v3.2.1
My problem is that the internal sdcard is no longer recognized
i can't install applications (insufficient storage)
i can't access the recovery
the tablet boot every time like if i did a factory reset
factory reset doesn't resolve the problem
i can install some applications by copying them directly to /data/app via adb
i can change permissions via adb
i can copy files to /mnt/sdcard via adb
when i open the files manager, the sdcard show nothing
Please Help
NicholasMora
2013/08/21 - 15:18
Did you do click yes or no when it asked you Do mandatory format when flashing the rom?
shoppy
Netherlands
2013/08/23 - 14:26
Hi Guy's,
I updated to the Onda 3.2.1 version (v2) but dont like the bootanimation much.
Mow I found a realy cool one but cannot replace the system/media/bootanimation.zip because it is write protected.
How can I make de system dir write enabled?
John
92 Guest(s)
Devices in use: Desktop (79), Phone (13)
jomama
biggfafa
himikus300483
CyberByte
printerr724
KarlCharlson
