[ ROM ] Onda V972 root custom firmware v2.0 (2013-03-30)
alligatorluke
2013/04/03 - 01:22
First I tried to update but even if PhoenixSuit said everything went fine, the tablet still stopped to the green Emergency screen. Therefore I went for format and install, and everythng went fine but... all the changes are regurarly lost...
groundhogman
Forum Posts: 32
Thanks Received: 8
2013/04/03 - 01:28
Normally  when you format and install all old firmware/software is removed and fresh put on.I can only think it might be corrupted firmware,try downloading a fresh copy and install.
Make sure you have the right version of firmware for your tablet.There are 2 versions of v972.
alligatorluke
2013/04/03 - 01:31
Unfortunately I already tried that... installed 1.35, 2.0, SuperNova_3.1... everything goes fine until I restart the tablet... and then all the data content is lost and you restart from scratch with tutorial and all the application on the main screen as when you have just flashed a rom...
kaotikjezta
2013/04/03 - 05:32
Is there any way to update without losing everything on my tablet. When I did the 1.35 update I chose the non format option and still lost everything
msav
Forum Posts: 71
Thanks Received: 13
2013/04/03 - 17:33
whenever you flash , update. ect. there is always a chance you can lose all data.
Rule of thumb Before you do anything use titanium backup to backup all your apps.
Another rule of thumb backup the rom with CWM or TWRP before doing anything.
This way your covered no matter what happens  You can always restore you previous image if the rom your testing out is complete crap. and if the rom is good you can restore all your apps with TB.
I never trust a non format upgrade with phoenixsuite, or a cwm install without clearing data, cache and dalvik.
Ps after you backup with TB you will need to copy the tb folder to your ext sdcard or your pc or you will lose it all.  also do the same with your CWM backup folder otherwise you will lose it as well.
If you have games that have obb folder you will need to back that up as well or you will have to redownload the data after the restore.  TB does not backup data files so backup the entire android folder to be safe that includes the odb folder
The following users say thank you to msav for this useful post:
ankar84, kaotikjezta
Thanks Received: 3170
2013/04/03 - 18:57
Just a quick note...
In addition to existing CWM Recovery support in ArcTools, I'm currently adding TWRP Recovery (build by ankar84, thanks to him !) more info on this soon.
ankar84, jored1222
nick789uk
Forum Posts: 45
2013/04/03 - 19:48
Hi folks thanks for the rom all appears fine apart from catch up tv having a blank screen and only playing audio, the strange thing is the adds play but the programmes just audio, Netflix, itv player and bbc player all work fine, worked ok on 1.35 any help with this.
Nich
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/04/03 - 20:43
It's not just YouTube...  Some games such as Marble Blast do the same thing. Black screen, ad on the bottom and music.
MindMe
Forum Posts: 14
2013/04/03 - 20:46
oh, so i'm not the only one who has black screen on YouTube (besides audio is playing)?.. interesting.
inner "4K videoplayer"works fine for me though.
2013/04/03 - 21:46
I'll see if I can fix that video problem, but in the worse case it's probably be fixed soon by Onda thru another firmware update and I'll quickly rebuild the custom firmware.
msav
Forum Posts: 71
Thanks Received: 13
2013/04/03 - 21:52
Onda probably rushed to get this firmware out. While a lot of improvements were made, they obviously did not test everything and assumed that most things would just continue working.
I hope that the reason that the other manufacturers of A31 tablets have not released their update is due to them perfecting their update.
That being said. I have not found enough issues that bother me to really complain and I am glad they got this out to us quickly.
TechBalloon365
2013/04/04 - 15:16
Seems that everybody has the black screen issue with the Youtube app.
Mobile Youtube through browsers do not have this issue though on the tablets we have tested.. strange..
msav
Forum Posts: 71
Thanks Received: 13
2013/04/04 - 15:45
This is probably due to the GPU optimization changes done with sdk 2.0
The fix could either be ondas side or fixed on the individual apps side. Hopefully the allwinner tablets are popular enough to get the attention of the app developer. Can we really expect onda to go down checking every single app for compatibility.
This is just speculation. Hopefully it is an easy fix.  I would think if onda spent the time making sure netflix and the other popular apps worked that they would have made sure youtube worked.  Maybe those apps work with the gpu differently.
Just thinking out loud.
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/04/04 - 16:15
It's not the app. It's several apps. I can think of at least two offhand. Worked before but not after.
When are they going to fix the charging issue? Why can't I use my tablet and charge it at the same time?
msav
Forum Posts: 71
Thanks Received: 13
2013/04/04 - 16:21
I realize it is more than one app. I was just trying to to theorize way some apps work ans some don't Perhaps there are things in common with the apps that don't work, that a single fix would fix them all.
I have had no problems using while charging my tablet at the same time using the stock charger or an Ipad 4 12W charger. If I try it with a lesser power supply it will go from charging to not charging intermittently.
billkaroly
64 Guest(s)
Devices in use: Desktop (58), Phone (5), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
