Onda has just published a firmware update version 1.35 for their V972 tablet, here is a custom firmware based on this release.
Build information
Linux Kernel: Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #6 SMP PREEMPT Fri Mar 8 21:02:04 CST 2013
Android system: onda/fiber_onda978q9/fiber-onda978q9:4.1.1/MASTER/20130309:user/opinions-on-teclast-p90hdst-keys
Google Translation of firmware v1.35 revision history from Onda gives the following in Ch'English:
to enhance the stability of the system disk repair prompt
solve the 4.5 version of the call of the micro-channel noise problem
application installation space recovery 2GB capacity
perfect the OTA upgrade function
amended the previous version of the firmware some models random problem can not burn
- added ArcTools for easy ClockworkMod Recovery (CWM) installation, see details here
We need your support to continue building and improving our firmwares, please consider making a donation if you appreciate our work. | ![]() |
Download: kasty-onda_v972-41-v135-rooted.zip
Please note that I haven't yet tested this firmware as I don't have my Onda V972 with me, feedback welcome.
mml78, lucsarou, toadskin, jamic, skraneveld, lee99, nonolol, SDTLM, algem, ankar84, sandervet, jored1222, gekonko, lahdee, wildthing66, alannapk, Khangsan3 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/02/08
I installed ClockworkMod Recovery from the tutorial.
But now it would not start antymore. It only boots in ClockworkMod Recovery and give some errors like:
E: Can't mount /Cache/Recovery/command
E: Can't mount /Cache/Recovery/log
E: Can't open /Cache/Recovery/log
E: Can't mount /Cache/Recovery/last_log
E: Can't open /Cache/Recovery/last_log
If i select reboot now it reboots but starts ClockworkMod Recovery again.
Can anyone help me witht his error?
aloksinha2001 said
is
there
any
way
to
flash
this
using
existingtablet,i do not have access to desktop win or Linux.
I've never tried, but extracting each NAND partition images from the main firmware image and flashing the separate images might work, at least it does on the Arnova 7 G3 tablet (model based on older Allwinner A10 SoC)
2013/03/08
MindMe said
i have now kasty_v1.33 version and really happy with that - seems really stable. So i am not sure if there is a reason to flash it to v1.35
do you guys see any really noticeable improvements in this v1.35 if comparing to last one?
I only had the official v1.33 version for like 2 days and I was disappointed because it was freezing most of the time. I don't know if it was due to the update (I've updated the firmware from the out of the box v1.32 to v1.33 without format) or not. The moment I switched to 1.35 (with format) things became more fluent and I had no problem since.
Now I'm thinking to try either the kasty_v1.35 or supernova 3. Did anyone install the recently released supernova 3?
2013/02/24
Hi my friends, I'm new on this forum, I beg your pardon for my bad English, I'm french(Quebec). I installed new version v1.35 with Phoenix suit 1.06 on my tablet yesterday. I'm very satisfied, no bug up to now, screen is more sensitive, colors are better, finally no problem. Thanks a lot at developer(s), really, reallly good job !
2013/02/14
Hello hard workers!
I'm using supernova rom 3.0 now. Als based on 1.35 Working perfect, especially when using Nova launcher. But battery live is only few hours...
Only thing I've changed is telling te tablet always to use the GPU for 2D. This makes browsing much smoother.
What are the experiences with this rom regarding battery live? Better then the supernova, or the same?
kind regards,
Algem.
2013/02/14
I'm running supernova 3.0. Smooth, fast and stable is my first experience.
But problem for me is the battery live. Battery drains to fast! But maybe thats because I switched on "Force GPU rendering" in the developer options?
Other problem with supernova 3.0 is that lots of apps in the Google play store are 'not compatible'. Same apps (like ArcGIS and Collector for ArcGIS) worked perfectly in my previous rom (kasty 1.33)
kind regards,
Algem.
59 Guest(s)
Devices in use: Desktop (48), Phone (11)
cutierogue
