[ ROM ] Onda V972 root custom firmware v1.33 (2013-02-28)
nutscratch
46
2013/03/04 - 22:22
I also have had issues with green writing but just leave it and it does boot. I also installed Nova launcher which helped a bit. My apps say they are not installed but after going back and forth to app area they do load slowly.
I have reflashed my tablet 20-30 times since  i bought it. I know it will eventually become a good item. People are working hard to fix the problem. I try to donate when i can to help them.
I find NFS game causes trouble also.
ROMSY
47
2013/03/04 - 23:47
Everything seems to be working, except Form SuperSU.
Everytime when i open it,it wants Tod upload the binary after some second i only get an error.
Someone knows why?
robinandroid
Forum Posts: 11
48
2013/03/05 - 11:14
slojustme said
I have problem with 1.33...
Gmail and play app are crashing all the time, i cant use it... Any suggestion?
Go into the settings, apps, clear cache, boot into recovery, clear dalvik and restart
Same problem here (Gmail and Play crashing). I did a reboot in recovery mode and cleaned the cache. It did not solve the problem. Is re-flashing the only option ?
To those with problems with rooted 1.33 rom, I experienced problems with stock 1.33 rom too. So I don't think the rooted rom is to blame. The problems are in Onda's rom. Let's hope the cause is not some defect in the hardware.
Onda V972 -> rooted with Onda_Allwinner_A31_root_v1_0.zip -> factory reset -> stock V1.33
amarillo
49
2013/03/05 - 12:45
Thanks, admin!
Your custom rom works like a charm on my V972! It saves us all alot of time!
And with nova launcher I had not a single crash. Same with your earlier version.
With the new rom the "system read-only" problem is still there. And I can not remount with write access... (tried with TotalCommander)
Did you find a workaround for this problem?
I have the problem with the SuperSU binaries as well, but I dont know if it is a real problem since programs like titanium backup still get root access...
ecarusel
50
2013/03/05 - 13:49
Jena Plissken 1975 said
Please help me.
I have flashed my v972 with custom rom 1.33.
It worked fine for 2 days.
Now, when I press the power button, after the onda screen, the boot blocks with a chinese screen:
2013-03-04-09.31.21.jpgImage Enlarger
I don't know what does it mean. Do I have to re-flash v1.33? Someone has the same behaviour?
I had same problem, booted to recovery and made factory reset.. I don't remember if stock recovery has factory reset.. fortunately I had installed CWM recovery..(To boot in recovery Press home button ,and power button without releasing home button. wait while "core 4" image appears.)
famimon
Forum Posts: 20
51
2013/03/05 - 14:03
It means that the systems has to do some checkings, leave it like that, it should boot in some minutes, I still don't know why doest it show that message
rodhunt
52
2013/03/05 - 14:16
I have 1.33 loaded ok on my v972.  As I have mentioned earlier there are apps which could be installed in 1.21 which can no longer be installed now.  I have have manually copied the apk files onto the internal card and tried to make the install with a dozen different installers.  Every time I simply get the message "X App not installed".  Can anybody help me to solve this problem.  Is there someway to force the apps to load and bypass this message ??  I do have ticked in security "Allow installation of apps from unknown sources".
ROMSY
53
2013/03/05 - 14:30
Is that the reason why i can't use Adblock?
revjim
54
2013/03/05 - 15:26
ADMIN-
Can you help ecarusel and I. We have done everything by the book here. Our tablets worked fine for a day or two and then when we went to power them  up the Processor Core Logo appears and then the ONDA logo flashes and then instead of going into the boot process a black screen appears with two lines of Chinese and then sits there. A respondent in this forum said it means "the system is just checking some things" and to wait until it is done. Well I waited for 2 or 3 minutes and nothing happened. My wife waited for here tablet longer. Still nothing. To correct this issue I need to do a factory reset/wipe date. I am thankful for your CWM recovery because I was able to do a back-up and then full restore. But this can't happened everytime I power  up. MAJOR PROBLEM
ADMIN- I want to thank you so much for your hard work dealing with issue for us. I am going to make a donation for sure. If I didin't stumble upon this forum I would have been hopelessly lost.
Jim
famimon
Forum Posts: 20
55
2013/03/05 - 15:38
I personally had the same problem and had to wipe all to boot again (I thought the rom was corrupted and didn't wait) just to have the same issue again, I then installed another custom ROM (supernova 2.0) also based in 1.33 and seems to be fine, but some users from its Spanish forum report to have exactly the same error with that ROM, they say the message means "Performing auto-test, don't disconnect from power" and that after leaving it plugged in for some minutes the tablet starts normally.
Will keep my fingers crossed, I don't want to wipe all my apps again
revjim
56
2013/03/05 - 15:50
Greetings famimon
I installed the CWM recovery from this instructions the admin has put together. I set my tablet the way I want it with all the apps. Except the ones that won't install now. (that is another issue all together) I did a full back-up. takes about 5-7 minutes. I did my first full system restore because of this boot issue. And my tablet booted successfully, fully restored. I am happy with that at least. But I need to use my tablet regulary and this posses a major problem.
famimon
Forum Posts: 20
57
2013/03/05 - 16:00
Yeah, I really don't know what causes the problem, I should make a backup myself, just in case
mml78
Forum Posts: 21
58
2013/03/05 - 20:00
In the Spanish forum htcmania they are now a few people trying one soluction to fix this problem. It seems it is related with the way onda v972 mouts in boot sequence. This original solution comes originaly from the chinese onda's forum:
http://www.htcmania.com/showthread.php?t=563920
Hope this can fix this BAD problem.
ecarusel
59
2013/03/06 - 09:43
revjim said
ADMIN-
Jim
  Hi Jim. I am not an expert, just curious user.. After the post, I met the green script again. Before green script , my all apps gave error so I forced to close the tablet and opened..woha!.. green script.. I waited longer. (more than 5 min.) and it continues booting normally.. I don't know the cause of problem.. I suppose it is about user data (I think some corrupted files on internal or external sd card.) Because when I wiped to factory reset at previous event, Everything gone normal..Thats all my experience..
If problem goes on.. I suggest make full update with PhoenixSuite.. install cwm recovery with Arctools (thanks to admin) and take a backup with cwm...
good luck.
famimon
Forum Posts: 20
60
2013/03/06 - 10:13
That's the forum I'm following, it seems that when the green characters appear it's actually wiping the sd content, no idea why it's that happening but doesn't appear to be a custom rom issue but a bug from 1.33
99 Guest(s)
Devices in use: Desktop (83), Phone (15), Tablet (1)
makaryura
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
