[ ROM ] Onda V972 root custom firmware v1.33 (2013-02-28)
blokkie
2013/03/01 - 11:52
Hi Guys,
I'd like to tell you dat I follow this post very closely because my brandnew Onda V972 is shipping by a friend today from Beiing to my place. What a good work you all do !!Laugh
I hope there will be a fast and stable ROM in the future fot this faboulous Tablet
Thank you so very much !!
Greetz Wink
akincube
Forum Posts: 13
Thanks Received: 9
2013/03/01 - 12:01
PLS HELP ME!!!!!
I MISTAKENLY UPGRADE MY ONDA V972 WITH FIRMWARE FOR V812
I UPGRADED WITH V1.33 MEANT FOR ONDA V821 INSTEAD OF THE V972
MT V972 IS NOT STARTING AGAIN.
PLEASE HELP !!!!!!!!
szajbus99
2013/03/01 - 13:36
How can i unroot my onda v972 with cwm?? Or can you create cwm with all changes without root?
jyams
2013/03/01 - 15:31
akincube said
PLS HELP ME!!!!!
____________________
Don't get upset.  I bricked my 972 yesterday by unplugging the usb cable by mistake while running the Phoenix routine to flash the v1.33 firmware upgrade.  All you need to do is the following:
1.  Hold down on the "power" button for a count of 20 just to be sure the tablet is powered off
2.  On your laptop/pc, start your Phoenix program and follow the normal instructions for flashing the 1.33 upgrade.  Your laptop/pc won't be able to recognize a connection to the tablet.  Just ignore and select the "firmware" button and proceed to select your flash file and connect your tablet to your laptop/pc.  See #3
3.  When you hold down the "home" button, connect the usb cable, and press the power button 10 times you should see the Phoenix program recognize your tablet like normal (even though it didn't recognize the tablet at step #2).  When you get the upgrade window click "yes" to format and upgrade your firmware.  When finished, disconnect usb and power-up the tablet.  This should solve your problem.  It worked for me.  The way Onda has set up this tablet it is almost impossible to brick it.
Hope this helps.
The following users say thank you to jyams for this useful post:
Klein Yair, bhabes1954
akincube
Forum Posts: 13
Thanks Received: 9
2013/03/01 - 16:44
@jyams, Thanks a million.
I was able the computer finally recognize the tablet after several trials and was able to load back the V972 firmware. Its now working, though with firmware v1.32 (but that is way better than a bricked tablet).
Please when is the rooted v1.33 for V972 going to be available?
Thanks, Thanks and Thanks.
akincube
Forum Posts: 13
Thanks Received: 9
2013/03/01 - 16:50
jyams said
akincube said
PLS HELP ME!!!!!
Hope this helps.
Thanks. Very helpful Smile
The following users say thank you to akincube for this useful post:
bhabes1954
jyams
2013/03/01 - 17:01
You are VERY welcome.  I've been helped by many others before so just trying to give back to the community.  Keep watching the OP (original post #1) in this forum and you should see the post updated to reflect the rooted image is ready for download.  Right now the post says "soon".  The OP said in a later post that it would be "ready by the weekend", so today maybe??  He also said there would be a custom CWM Recovery available also.  Although, Davlin has said that the stock recovery in v1.33 is a touch recovery.  I already loaded a CWM version before checking, so am hoping someone will post the stock recovery image from v1.33 for me :) .  Thanks.
Thanks Received: 3170
2013/03/01 - 17:10
I'll publish a first custom firmware based on official 1.33 today, I don't have enough time to complete all I wanted to do on it, so I'll improve it later, will post here when it's ready.
About Recovery, I already mentioned in post #1 that I have made available an easy ClockworkMod Recovery (CWM) installation, see details here.
blokkie, toadskin, pabl0, mike
2013/03/01 - 18:37
Post #1 updated Wink
gekonko, tommyamu, MindMe, mml78, Frontline62, thorak, Stolz, toadskin, SDTLM, jored1222
Omut
2013/03/01 - 20:12
Please make a firmware release in CWM Recovery ZIP format. I cannot use PhoenixSuit tools with my brick, only CWM recovery is alive.
ferrochrome
2013/03/01 - 22:33
The firmware hangs permanently
Nick1977
2013/03/01 - 23:29
Works well on mine. Works better than 1.32
Shaggs1983
2013/03/02 - 01:00
Downloading now!
This forum is awesome. Heaps of community help. So far I've rooted my tablet, flashed all the new firmware with phoenix, flashed custom roms and unbricked my device. All thanks to you guys. Keep up the good work and let it be known that you are helping heaps of people out there.
implode99
2013/03/02 - 02:38
i think some of the root permissions are off , Adblocker and startup animation cant access the root with Roomtoolbox .
Dvalin21
Midwest City, OK
Forum Posts: 41
Thanks Received: 10
2013/03/02 - 06:28
Found out that the stock ROM comes rooted, but u have to install supersu yourself and the stock recovery is touch enabled
The following users say thank you to Dvalin21 for this useful post:
aryanitinkumar, bhabes1954
82 Guest(s)
Devices in use: Desktop (74), Phone (8)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
