[ ROM ] Onda V972 root custom firmware v1.32 (2013-02-05)
xeresis
Forum Posts: 14
106
2013/02/28 - 10:25
xeresis said
brad1601 said
Ok lets just agree to disagree, in my experience with this rom, it doesn't have the R/W access (even 'admin' has acknowledged it as a bug) to the system files which is needed to be able to delete the stock launcher and TB can't magically change that
Also not having the choice doesn't necessarily mean you've uninstalled it, it just means you've selected your other launcher as the 'always use' option.
my friend i dont know what i tell you, yes the permission have r/w problems but i and many other users have success uninstall the stock launcher because dosn't show nowhere, dosn't show after uninstall in titanium backup, dosn't show in nova launcher in option 'always use' ect. if do you know any other way to test if dosn't uninstall success please tell me, a give a try.
maxxxy
Forum Posts: 21
107
2013/02/28 - 11:18
if possible please  insert cwm recovery in New 1.33 thank you
108
2013/02/28 - 11:24
Our custom firmware will be stock, with the original recovery.
We'll provide a separate procedure to install CWM-R easily.
Frasfax, jyams, aryanitinkumar
robinandroid
Forum Posts: 11
109
2013/02/28 - 11:45
admin, is it possible to change the permissions of the external media storage in the rooted 1.33 ?
in /system/etc/permissions/platform.xml
change
<permission name="android.permission.WRITE_EXTERNAL_STORAGE" >
<group gid="sdcard_rw" />
</permission>
to
<group gid="media_rw" />
</permission>
In principle this gives rw access to external sdcard to any app.
Onda V972 -> rooted with Onda_Allwinner_A31_root_v1_0.zip -> factory reset -> stock V1.33
maxxxy
Forum Posts: 21
110
2013/02/28 - 12:16
sorry ..... which procedure?????
There is a zip to flash cwm?
111
2013/02/28 - 12:21
maxxxy, you can check here:
http://www.arctablet.com/blog/forum/onda-v812/onda-v812-root-custom-firmware-v1-32-2013-02-05/page-3/#p19499
Our procedure will be even simpler than that, but it's not finished yet, we'll post an update when it's available.
fabioboston2012
112
2013/03/01 - 21:02
Its not about firmware but the tablet instead, Can anyone install Drag Racing and testing it ? In my tablet is very slow game :S In my mobile phone with arm v6 single core is very fast in this game!
https://play.google.com/store/apps/details?id=com.creativemobile.DragRacing&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5jcmVhdGl2ZW1vYmlsZS5EcmFnUmFjaW5nIl0.
skraneveld
113
2013/03/04 - 10:32
Received my Onda V972 friday and installed the 1.32 Custom Rooted firmware from this site and works great for me. No more chinese crap apps.
Thanx.
sibi
114
2013/03/09 - 10:14
1.32 custom firmware seems to be the best firmware at the moment for the v972. It is not what it should be,but at least it doesn't have the crappy performance of the 1.33 which freezes all the time.
One problem with the 1.32 is that after the auto update of supersu the root is lost, no update should be done in supersu app. Another problem is the not so stable performance, it may freeze once a day.
edd1988
115
2013/03/16 - 00:06
yes work perfect  for my tablet Vido原道N90四核FHD quad-core ( allwinner A31) thank you very much
69 Guest(s)
Devices in use: Desktop (62), Phone (7)
chimo014
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
