[ ROM ] Onda V972 root custom firmware v1.32 (2013-02-05)
TechBalloon365
91
2013/02/26 - 00:31
I was using the stock 1.32 firmware and my Onda went into bootloop again..Let's see how it goes with this rooted firmware!
Guys please post clearly of how to install CWM Recovery on the ONDA! So many people ask!
92
2013/02/26 - 00:54
There's a link in the V812 section on our forum.
I'm working on an even simpler method (root required) that just requires a few clicks, I should publish it these coming days when I'm done with the tests.
Dvalin21
Midwest City, OK
Forum Posts: 41
Thanks Received: 10
93
2013/02/26 - 04:46
Unzip all three files in the zip to the root of the internal storage. Download terminal emu later and install to tablet. Open it, type in su and press enter. Then type in the second command line and enjoy. There is a third line that will reboot the tablet into recovery
moiise
94
2013/02/26 - 06:23
Huummmm i cant install some app becose the playstore said (your device isn't compatible whit this version)
Onda V972 v1.32 root!!
brad1601
95
2013/02/26 - 06:33
brad1601 said
xeresis said guys i have full root with 1.32 rootet rom!   first install  CWM recovery and then install from here  the logo v3 zip (select install update from zip) after that my onda have full r/w access.   and one question please... my tablet have 12gb internal sd and not 16gb, is that right?
I tried this... Still can't delete the stock launcher :( permissions not granted.   Really hope we can get a fix for this soon!
 xeresis said stock launcher can delete with titanium backup
You can't actually, it may say its deleted but its actually not because it doesn't have R/W permission for that directory.
'Admin' can we get any updates on this issue please? Its the only reason I'm not using this as my standard rom as I find it runs much better once the stock launcher is un-installed (Which we can't do with this rom)
Thanks again for the effort put into making this rom for us.
Duesentrieb
96
2013/02/26 - 08:07
the boot loop problem ist still there with the 1.32 :(    ...this makes the tablet unusable for me in urgent situations when I have to rely on my hardware. I hope, the manufacturer will solve the problem soon.
Clay338
ITALY Lecce
97
2013/02/26 - 08:57
Clay338 said
CONFIRM NO CONFLICT OR CRASH IN GENERAL.
I succeeded with vers. 1.2 previous firmware but I could not understand what were the steps made​​.
Then I restored the 1.2 rebuilt the steps and got this far but I will not confuse you.
USE THIS:
1) Upgrade to new firmware 1.32;
Operations to be performed:
1) Restore and backup (only for those who already had updated and installed something)
2) Delete and disable everything that was written in Chinese on the desktop from the desktop mother the blue so to speak, and continue when we open settings or eliminating or ending if we have the opportunity;
3) Of all we need to eliminate wave widget including 360.ie cc. everything that is Chinese;
4) Once all the elimination Chinese open file manager go to SD card and clear them all CLEARANCE ALL  (Just hold on folders and screen opens click delete folder as in all) will only SD. -
4) Finished create folders Pictures, Movies, Music and just close all
5) Now what we want to install crash-proof. -
I hope it was clear in doubt, ask
I forgot my tablet Onda V972 is obviously not Rooted
A good make
Sorry for my English Wink
xeresis
Forum Posts: 14
98
2013/02/26 - 11:20
 xeresis said stock launcher can delete with titanium backup   You can't actually, it may say its deleted but its actually not because it doesn't have R/W permission for that directory.   'Admin' can we get any updates on this issue please? Its the only reason I'm not using this as my standard rom as I find it runs much better once the stock launcher is un-installed (Which we can't do with this rom)   Thanks again for the effort put into making this rom for us.
Are you sure? Maybe you dont give permission access from supersu to titanium backup?
My 1.32 rooted success uninstall without problem.
brad1601
99
2013/02/27 - 05:25
I think you'll find its actually not uninstalled, it looks like it is, but its really not. I have been granting permission to Titanium backup.
Open up root explorer and have a look in /system/app/ I reckon you'll see that Launcher2.apk is still there.
xeresis
Forum Posts: 14
100
2013/02/27 - 10:19
apk maybe still there But install of apk dont is...
can you joice run between stock launcher and other? if not then done, success uninstall ;)
brad1601
101
2013/02/27 - 10:41
Ok lets just agree to disagree, in my experience with this rom, it doesn't have the R/W access (even 'admin' has acknowledged it as a bug) to the system files which is needed to be able to delete the stock launcher and TB can't magically change that
Also not having the choice doesn't necessarily mean you've uninstalled it, it just means you've selected your other launcher as the 'always use' option.
maxxxy
Forum Posts: 21
102
2013/02/28 - 09:27
was released firmware 1:33
do an update!!
EffKay
Forum Posts: 11
Thanks Received: 4
103
2013/02/28 - 09:42
I want to modify the former post to a kind question. Wink
Do you plan to make a pre-rooted 1.33 Version without the chinese software, fixed preferences and maybe already installed Nova and wiped Launcher2?
Or, if not, can you give advise how I can do that by myself? Cool
Best regards
EffKay
104
2013/02/28 - 09:45
Thanks Effkay, that sounds more polite ! Wink
One is in the works actually, I'll just do Chinese apps cleanup and root, Nova can be added by the user.
EffKay, Frasfax, robinandroid
xeresis
Forum Posts: 14
105
2013/02/28 - 10:20
my friend i dont know what i tell you, yes the permission have r/w problems but i and many other users have success uninstall the stock launcher because dosn't show nowhere, dosn't show after uninstall in titanium backup, dosn't show in nova launcher in option 'always use' ect. if do you know any other way to test if dosn't uninstall success please tell my to give a try.
125 Guest(s)
Devices in use: Desktop (116), Phone (9)
spiik
nikitamaan
VMILCINOV
