Onda V972 root custom firmware v1.32 (2013-02-05)
Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5 Topic Rating: 5 (8 votes)
2013/02/19
10:10
Forum Posts: 20
hello friends
I put the rom and it seems to me excellent.
But the speaker volume audio seems low
theres a way to turn up the volume?
2013/02/19
10:45
Forum Posts: 14
brad1601 said
xeresis said
guys i have full root with 1.32 rootet rom!
first install  CWM recovery and then install from here  the logo v3 zip (select install update from zip)
after that my onda have full r/w access.
and one question please… my tablet have 12gb internal sd and not 16gb, is that right?
I tried this… Still can't delete the stock launcher :( permissions not granted.
Really hope we can get a fix for this soon!
stock launcher can delete with titanium backup
2013/02/19
11:00
Forum Posts: 14
robsin08 said
guys can someone please post instructions on how to install cw recovery thanks
download and install android terminal emulator (its free)
download and install busybox (its free)
open busybox and let him to success smart install
download zip from here :
Copy all three files , extracted from the zip, to the SD card (without folder)
open terminal emulator and write :
su
busybox sh /sdcard/install-recovery.sh
done! install success , write another command To reboot into recovery
busybox sh /sdcard/reboot-recovery.sh
(now with home press and power boot start from cm recovery)
for full instructions read here
2013/02/19
11:21
Forum Posts: 14
my false, finaly i have access to copy paste files in folders (like permissions folder) but no full r/w access to paste or delete folders , its a strange bug…look forword to full r/w root rom
2013/02/19
15:42
Forum Posts: 20
How to install the recovery??
Thank you.
someone tells me something about the volumes??
it seems to me very low
else is a way to increase
2013/02/19
20:00
Hi everybody. For those who have permissions problems on External SD Card, the solution is to format it with extFat. :)
Onda v972
2013/02/19
20:26
Forum Posts: 11
Thanks juve17, how can I do that ?
Onda V972 -> rooted with Onda_Allwinner_A31_root_v1_0.zip -> factory reset -> stock V1.33
2013/02/19
22:52
I find this ROM laggier than stock ROM, why could this be?
I also noticed on stock rom and this that a lot of games wont play, they will load and when i click play on the menu i hear the games music or sounds in background but frozen on screen
2013/02/20
11:18
Forum Posts: 3669
Thanks Received: 994
Online
Archos 101 XS
84
Could you be more specific about what's lagging and how you measured the lag ?
Our custom firmware is fully based on stock firmware and I can't think of any change that would impact the system performance. About the games that you found non working, please post the names/urls on Google Play Store, maybe we can have a look.
2013/02/20
14:10
Forum Posts: 14
the game blood brothers dont work, any solution? :(
2013/02/20
14:28
Hi sometimes it will be ok others very slow opening the apps menu or opening the notifications menu with settings will have a delay in opening or jump up slowly.
A game for example is the Simpsons tapped out. It will download all of the DATA to play then goes blank
Something i just noticed, when you unlock the screen the actual camera on the back makes a noise as if the lens opens. It does this everytime
Thanks for your help
2013/02/21
07:52
my V972 is now running stable with this 132root installation, fantastic. But the superSU want to do actualization of su-binary and always fails. I tried so many things but I can't find solution. Anyway the root checker says that root access is OK.
What might be the problem of SU-binary? (e.g. I tried install without SD-card, tried to change the RW-settings,… but all fail on the su-binary-update)
2013/02/23
01:27
No Archos/Arnova device
88
Here is one of the first rooted custom firmwares for the Onda V972 tablet, it is based on latest official V1.32 release from Onda.   Build information:  Linux Kernel: Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 – Linaro GCC 2012.02) ) #3 SMP PREEMPT Mon Feb 4 11:38:13 CST 2013 Android build: onda/fiber_onda978q9/fiber-onda978q9:4.1.1/MASTER/20130204:user/test-keys Custom firmware features: – root with latest SuperSU 1.04 (free version) – system default setup English – removed most Chinese and unnecessary applications – Google Play Store fixes so more application are visible/compatible Download: kasty-onda_v972-41-v132-rooted.zip Flash with PhoenixSuite (tutorial)
Thanks for your post. I have successfully loaded the version 1.32.  One question I have is with vesion 1.21 'Event Cinema', 'TripView Lite' and 'Live Traffic Sydney'  were all loaded and running fine.   With 1.32 the playstore says not available for your device. If I try to manually install the apk,  you simply get message 'App not istalled'.   Do have any solution to help solve this problem ?
2013/02/23
03:20
I'm getting an error when I try to do the format install:
It worked when I just upgraded though.
Now it's getting stuck at 3%. I hear the Tablet disconnected from the computer during the upgrade even though I'm not disconnecting it.
Okay it reformatted but SuperSU still can't install.
2013/02/25
17:30
ITALY Lecce
CONFIRM NO CONFLICT OR CRASH IN GENERAL.
I succeeded with vers. 1.2 previous firmware but I could not understand what were the steps made​​.
Then I restored the 1.2 rebuilt the steps and got this far but I will not confuse you.
USE THIS:
1) Upgrade to new firmware 1.32;
Operations to be performed:
1) Restore and backup (only for those who already had updated and installed something)
2) Delete and disable everything that was written in Chinese on the desktop from the desktop mother the blue so to speak, and continue when we open settings or eliminating or ending if we have the opportunity;
3) Of all we need to eliminate wave widget including 360.ie cc. everything that is Chinese;
4) Once all the elimination Chinese open file manager go to SD card and clear them all CANCELLANDO.PRATICAMENTE ALL (Just hold on folders and screen opens click delete folder as in all) will only SD. -
4) Finished create folders Pictures, Movies, Music and just close all
5) Now what we want to install crash-proof. -
I hope it was clear in doubt, ask
I forgot my tablet Onda V972 is obviously not Rooted
A good make
Sorry for my English Wink
admin: 3669
globula_neagra: 1873
Guest Posters: 36
Members: 74165
Forums: 122
Topics: 2798
Moderators: HaroldG (117), globula_neagra (1873), exelletor (344)
Administrators: admin (3669)
