[ ROM ] Onda V972 root custom firmware v1.32 (2013-02-05)
xeresis
Forum Posts: 14
46
2013/02/12 - 21:08
hello people, now i need some help.
i have root firmware 1.32 but i have lot of random crashes and i need root again and again because at every crash the tablet dont boot ( i see the logo screen) and dont have hardreset or somethink for boot or recover os . any ideas for random crashes ?
1st4ck
47
2013/02/14 - 23:44
I have the same problem. Any ideias?
Btw i can't connect my tablet to hdmi TV. (on a LV 32'') but it works on a (Samsung 42'' 6100).
robsin08
48
2013/02/15 - 13:50
hello im a new onda v972 user.. i just have one problem though.. every time i push the power button for the lock screen to come up it takes a second for it to open and it always make a sound like your turning on a pc monitor or a television.. power surge i guess? is it normal? or my unit is defective? thanks..
robinandroid
Forum Posts: 11
49
2013/02/15 - 16:43
Hello V972 owners !
I did root my tablet using the "Onda_Allwinner_A31_root_v1_0.zip" and tablet's update app.
I see that many people use the "Phoenix" suite.
My question is what is the difference ?
Thanks.
Onda V972 -> rooted with Onda_Allwinner_A31_root_v1_0.zip -> factory reset -> stock V1.33
50
2013/02/15 - 16:48
Flashing our custom firmware (see post #1) with PhoenixSuite updates the tablet configuration so Google Play Store lists/let you install more apps and it's based on latest official Onda firmware version 1.32.
If you're happy with your current setup, there's no need to flash Wink
robinandroid
Forum Posts: 11
51
2013/02/15 - 17:05
Thanks for the reply admin !
The long story is that I used the Onda_Allwinner_A31_root_v1_0.zip because this was the first way to root I found. But after a few days I got some apps shutting down unexpectedly and finally (today) the tablet did not boot again being blocked at the Onda logo. I managed to do a factory reset and the tablet is now with android 4.1.1 baseband 1.21. I happens to be rooted.
Now I don't know what to do. Is the system that is installed with the method described on post #1 more stable ?
I don't have a windows system running so the phoenix way is a bit more complicated for me. Is it possible to install this firmware using the update app that is on the tablet ?
52
2013/02/15 - 17:16
From the reports I've seen, firmware 1.32 seems more stable than previous versions.
Flashing a firmware (such our custom one) using PhoenixSuit is like fully resetting everything, it's a low level tool that works only with complete firmware images. On the other hand, OTA updates (small zip packages) aren't compatible with complete images so you can't fully flash a device this way.
As far as I know, PhoenixSuit is only available for Windows, I don't think there are similar tools for Linux yet.
I don't recommend using a virtual machine for these kind of things, as flashing programs are quite low level tools that require perfect USB ports handling. Best you can do is probably find someone with a Windows PC.
Here is our flashing guide if needed.
robinandroid
camargue
53
2013/02/15 - 17:51
my firmware is 1.2 d 'origine, to go up 1.32 can one make it directly by phoenix 10.5 .Soit take up 1.2 - 1.32 live broadcasting? .merci
54
2013/02/15 - 17:56
Coming from your stock firmware 1.2 you should be able to directly flash the stock or our custom 1.32 firmware with PhoenixSuit.
camargue
55
2013/02/15 - 18:03
My firmware is 1.2 d 'origine to take up fact to 1.32 me directly by Phoenix 1.05 by going up directly from 1.2 to 1.32 without passing by 1.0 and 1.21 accomplishable?
Excuse translation, thank you.
camargue
56
2013/02/15 - 18:06
Thanks you for the news .
aaronm13
57
2013/02/15 - 23:14
Is there any solution to the permissions problem usig this ROM. Trying to change some XML files but am unable to because of this issue.
brad1601
58
2013/02/16 - 04:24
I am also very interested to hear any developments on this issue.
Other than this small problem I've been very happy with how its been running so hopefully this can be addressed so I can delete the stock launcher and edit the XML files.
Thanks!
hlx70375
59
2013/02/16 - 10:11
is it ready root ?but my device only can read,can't write.somebody have the same problem?
robinandroid
Forum Posts: 11
60
2013/02/16 - 17:44
Thanks for the details. I learned something today.
Did you fix the permission issue in the custom firmware (I am talking about this problem: http://www.chainfire.eu/articles/113/Is_Google_blocking_apps_writing_to_SD_cards_/) ?
If not, can you include it in the next version ?
I think this fix would benefit a lot of users judging by the number of messages that can be found on the net complaining about the impossibility to let apps write on /mnt/extsd .
If it is possible to do the fix without a new firmware, it's ok but I have not discovered how to do it yet.
50 Guest(s)
Devices in use: Desktop (47), Phone (3)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
