2013/02/09
I've got the same problem like okimchi:
I updated the phoenix suite to 1.0.6 and I tried it already three times.
Before trying this I installed the stock update 1.2 and the root package via the update app.
I tried the 1.3.2 from onda.cn and the root custom firmware from this page!
Could anybody help me please?
Edit: I use windows 7 64 bit
2013/02/01
had the same problem and read somewhere that you need to go from 1.2 -> 1.21 ->1.32.
this worked for me.
V1.21 is not on the Onda site but i got it here
wwwDOTslatedroidDOTcom/topic/42136-quad-core-onda-v972/page__st__300
The following users say thank you to RomJohn for this useful post:
ankar84, MindMe, slowbuild
2013/02/08
You can find a update instruction here:
Somebody translated all the chinese to english.
2013/02/11
Thank you very much for the good instructions!
I'm getting an "Fel2Fes Error" in the PhonixSuit after it recognizes my V972 ... does anybody know what that is?
My steps:
- in PhonixSuit select the Firmware
- Turn off my device
- Plug USB-Cable while I press the Home button
- while I still press the Home button I press a few times the Power button
- the Computer is recognizing my device and startes the driver
- then PhonixSuit is telling me "Fel2Fes Error"
I already tried the following, without any change, still get the same Error:
- Update of PhonixSuit ... used 1.05 and 1.06 latest version
- reseted my device
- have version 1.20 and tried first to update to 1.21 and direct to 1.32
- rooted my device
maybe anybody has an idea?
Chris
2013/02/08
Hi arctablet. Something wen wrong during update. Right now I cant even go into recovery mode. When I press combination of home and power keys I always hear the signal from Windows that a new usb device is discovered but nothing happens on my Onda. When I plug out usb there is no posibility to turn on or turn on in recovery mode. Any idea. I could have RTA problems becasue I have rootrd soft onboard. Damn.....
2013/01/30
I've been flashing my V812 and V972 dozens of times already and the only problem I had so far was the V812 that refused to upgrade from firmware 1.0 to 1.32, the flashing progress bar was stuck at 0%: I had to flash 1.2 firmware first and upgrade from there.
Also, I've seen some advice in htcmania Spanish forum to remove the USB device in Windows and let it readd after the tablet is detected again during the flash process.
That's all I can think about for the moment.
2013/01/30
Dvalin21 said
I just heard that CWM Recovery is now available for this tablet, can anyone confirm.
There is one on XDA, I haven't tried it yet.
2013/02/12
can someone post the build.prop.
I have a nextway F9x - (same allwinner A31 with retina display). Tried flashing this 1.32. flashes okay, but I get to the unlock screen.. and the touchscreen is not active..
Just having some playstore compatibility issues... hoping to see what build.prop looks like and if this will help.
Thanks!
51 Guest(s)
Devices in use: Desktop (48), Phone (3)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
