2013/02/08
Hello to everbody.
I got a big problem. I started the upgrade procedure using Phoenix but when the download was to 87% an error from the Phoenix abort the procedure(the message was in Chinese and I saw in the dialog bar "No device attach"). Now my tablet doesn't start and I tried to push for long time the power button and even together the home button but nothing happens.
Do you have some tips to suggest me to switch on again the tablet or there is something to do?
Thank you in advanceÂ
P.S.
I was downloading the root custom firmware 1.32
2013/01/30
Hello Arctablet,
  This is Dvalin21 from XDA, I just saw a post by Msav and he made a good point.  What do you think we can do with the Archos firmware since its the exact same tablet? Other than the lower storage space? And of course the only thing I don't like about Archos, is that they try to make you pay for features that should come naturally to a tablet.
Hello Dvalin21,
Nice to see you hereÂ
It will be interesting to try the ARCHOS 97 Platinum tablet firmware on our Onda, I hope it will be fully compatible with our V972. I don't know exact product release dates, but it probably won't happen before next month, I'm keeping an eye on that...
About paying for features, you are referring to the codecs for the Video Player ? If that's it, actually what they say (I don't know if it's the truth ) is that they have to pay some licenses for DTS/AC3 and other codecs so they prefer to sell them optionally to keep the tablet price a little lower and only those who need it would buy them.Â
2013/02/08
robyrav68 said
Hello to everbody.
P.S.
try this
1) Shut down tablet (usb cable not connected)
2) Open PhoenixSuite and select the image included with the zip file with the "Upgrade" button ready for clicking.
3) Hold the "Back/Home" button and connect the USB to your computer.
4) Press Power Button 5 times.
5) A window should pop up in PhoenixSuite with two options. (I actually accidentally clicked the first one and wiped all data)
6) Done. Reset will take longer than normal.
The following users say thank you to xeresis for this useful post:
admin, segafan
2013/01/30
Thanks Arc,
  So do you think you will be able to do a Custom Recovery for the Onda v972?  Also, I've been looking around.  Over at androidtablets.net they have been moding the firmware for the Novo 9, (almost same thing) and I've asked to see if they could port some of the drivers for us.  I know that I've read that some user's have tried to install the firmware from the Novo onto the Onda, but the only only thing that didn't work was the LCD screen.  With that being said, I'm hoping that they would be able to pull the driver for the power management chip (if it has one) any maybe it could be ported into the firmware?  Thanks
PS: And thanks for having me
2013/02/08
Thank you so much Xeresis.
Yesterday evening I made this procedure and got the result.
Now work with 1.32 and thanks to everybody for your effort.
I hope in future to be able to give my support to the comunity.
I have one open point more. I see that my V972 take around 8-9 hours to charge battery completely. Do you notice the same for your V972? Maybe the power supply is not good enough?
Thank you
Ciao
2013/02/08
HI evrybody,
first of all sorry for my english,
I have a wave 972 (ONDA V972), I tried, after reading the various forums, to do the update to firmware 1.32..... I used PHOENIXSUITEpacket v1.0.5.msi program, that I downloaded from a file .rar, where there was also inside the file v972core4_1.32.img, in just a few steps it has updated but when I restarted it was stuck on the black screen of brend factory (-----(ONDA)WAVE since 1989-----) please help me! l it has only three days! I throw it away?
I am no expert in any of tablet PCs are a beginner.
Please follow Xeresis post #19 to flash and get your tablet working again.
I should also have a detailed procedure together for a video for that ready later this week-end.
2013/02/09
Hi,Â
I had the same problem with my new onda v972. It just start and stay forever in the Brand logo.Â
I tryed the guide of Xeresis but even it heped to point the direction it was not possible to fix my problem.
Here is the steps i did to get my tablet working again.
1. Download firmware 1.32 rooted from first page of this thread.
2. Download PhoenixSuit 1.05 (them upgrade to 1.06)
3. Open PhoenixSuit and Select Firmware, then select the img from Step 1 after unrar.
4. Turn of Tabled by clicking power button 10 seconds. (skip if tablet is already Off)
5. Click  and mantain pressed the Main button (NOT THE POWER)
6. Connect the USB to PC (KEEP pressing the MAINn button)
7. Click 10 times the Power button (while pressing the MAIN)
8. You will notice that on PC it will install drivers and Ask you 1 question.
9. The question on Step 8 is to Wipe or Not the Data.
(I tryed not to Wipe, but i had the Logo on start again, so to fix i had to wipe all data)
10. The tablet will update to 1.32 and you should have it working fine.
86 Guest(s)
Devices in use: Desktop (78), Phone (8)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
