Onda V972 - can't access "Internal SD-Card" so better say part of my internal memory
supernovio
2013/02/19 - 09:32
Hi all,
right now I can't access my partition that is called "SD-Card" (not external SD-Card!!! ... that one is working just fine).
SD-Cart = part of my internal memory that is called "SD-Card"
I'm now working on the problem for a few day's but just can't fix it. So I need some help :)
I tried already almost everything :( ... here a few examples:
- Factoy reset
- formating/partition sd-card (local) in CWM Recovery
- restore old backups
One thing that I can't do is using PhoenixSuite (tutorial) to update my V972 ... it shoes up an error that and i can't connect to the V972 (post on this forum)
Right now I have in "ROM Toolbox Lite" the following startup script working:
mount -o rw -t vfat /dev/block/vold/93:72 /sdcard
setprop EXTERNAL_STORAGE_STATE mouted
am broadcast -a android.intent.action.MEDIA_MOUNTED --ez read-only false -d file:///sdcard
with this script running I can see the SD-Card with all the files on it but only with the programm "Total Commander"
sdcard (properties)
drwx-------
UID: 0 root
GID: 0 root
but I can't edit anything and I can't change UID/GID ... only on one boot I could upload some files to the SD-Card but I can't repeat that action anymore
with programms like the "File Manager" or "Root Explorer" I can't access the "SD-Card" ... so I can't see what is on it
Anybody gots any idea?
ThanX
rustywires
2013/03/02 - 13:40
Hey I am having the same issue. Happened right after I installed CWM with arctools. I can see the sdcard in CWM. I had 1.2 installed
Managed to fix it. I did a factory reset from within the Rom and ticked the format sdcard box. Not sure why that worked when I formated it from CWM. Hope this helps.
84 Guest(s)
Devices in use: Desktop (74), Phone (8), Tablet (2)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
