onda v972 build quality
dogsbreath
2013/02/25 - 01:32
I have just purchased a onda v972, from Onda tablet. I have found that between the power plugin point to where the double speakers are, that when finger and thumb pressure is applied to the glass edge and case, i get a creaking sound that extends slightly into the display. its as if the screen has no been fixed down properly.
Has anyone got a similar issue.
Onda tablet say that it is nothing to worry about. It is only in this area. The rest of the screen is firm in the frame. I am not certain whether to return it and request a replacement. General feedback would be helpfull.
Thanks for you anticipated assistance.
billkaroly
Forum Posts: 61
Thanks Received: 6
2013/03/31 - 21:56
I just received my ONDA V972 from techballoon365.com and it came with 1.35 and the build quality is quite excellent. It was slow and sluggish at first until I rooted it and replaced the stock launcher. In regards to Launchers I tried Apex and Nova, settling for Apex. I have also upped the CPU speed to 1.152 GHz. Now I am thinking about a custom ROM but will probably wait and see how the next kernal update or two perform.
After I ordered it I discovered you could not charge the V972 while in use which is a real bummer for me. Hopefully this will be restored in a kernal update.
Currently Online: andreive
69 Guest(s)
Devices in use: Desktop (61), Phone (9)
hans41
rickybk
soniya07
ironmangitar
