2013/03/09
michaelmacdo said
Does anyone know if it is possible to get bluetooth working through USB (OTG & bluetooth dongle) on the Onda V972? If it is possible can someone please explain the process to get it working.
Onda firmware doesn't support this. You might want to look into CM10 or AOKP for Allwinner A31
2013/11/08
Hi, I'm a newbie and I hope it's OK to ask this, but can I change from kasty mod to CM 10.2 ROMs without uninstalling anything prior to it? I'd like to get the bluetooth support that CM 10.2 has. Thanks for your answers!
EDIT: sorry! I just realized that in order to install CM one needs to do a clean install, so there should be no problem
2013/11/08
Thank you for your reply Pingu! One other thing I was wondering, I benchmarked my V972 with Antutu yesterday out of curiosity, there it showed me in "device info", after I ran the full custom test, that the resolution is 1952 x 1536 (instead of 2048 x 1536). I just ran the test again and now it shows 2048 x 1440 in "display" => "resolution" (instead of 2048 x 1536). Does anyone know whether I've been cheated or is this correct? Could this have anything related with the ROM? (I'm on kasty latest ROM, no other mods done) Thanks again!
63 Guest(s)
Devices in use: Desktop (55), Phone (8)
