Did upgrade from v1.33 to v1.35 without problems using PhoenixSuit. V1.35 works fine on Onda V972.
Used Arctools to install CWM.
Get into CWM with folling error message:
Can't mount /cache/recovery/command
Can't mount /cache/recovery/log
Can't open /cache/recovery/log
Cant't mount /cache/recovery/last_log
Cant'T open /cache/recovery/last_log
The reboot option comes back into CWM.
Has to re-install V1.35 via PhoenixSuit to make Onda V972 operational again.
Regards,
B.Dewilde
Note. Is Onda 32Gb
2013/03/01
Hello, Did upgrade from v1.33 to v1.35 without problems using PhoenixSuit. V1.35 works fine on Onda V972. Used Arctools to install CWM. Get into CWM with folling error message: Can't mount /cache/recovery/command Can't mount /cache/recovery/log Can't open /cache/recovery/log Cant't mount /cache/recovery/last_log Cant'T open /cache/recovery/last_log The reboot option comes back into CWM. Has to re-install V1.35 via PhoenixSuit to make Onda V972 operational again. Regards, B.Dewilde Note. Is Onda 32Gb
I faced the same problem.
Ironically no compatible CWM for 32 Gb version. Best you can do is reflash it to 1.35 with Phoenix suite.
47 Guest(s)
Devices in use: Desktop (45), Phone (2)
VMILCINOV
