2012/09/25
I also have a lot of apps which gives the message, not compatible with your device.
I also have the problem with SU, updating binary fails.
But that is not so important, more important is the playstore. For example nu.nl can not be installed and it is an app i use a lot. Also tried to install separate apk file but then i get the message "not installed"Â
Using custom 1.32 rom.
Is there any solution?
Regards
SuperSU should work fine with our firmware.Â
Which firmware have you installed ? Have you followed the firmware flashing tutorial with PhoenixSuit ? Answering Yes to the mandatory format is important.
2013/02/14
Got the same problem: Lots of apps in the Play store tells me 'this item is not compatible with your device'.
when I install the same 'not compatible apps' from an apk, they seems to work perfect!
Using: Stock rom + rooted, removed chinees apps a.s.o
Tried to change the build.prop with the next settings (using the app: BuildProp Editor):
ro.product.model=Nexus 7
ro.product.brand=google
ro.product.name=nakasi
ro.product.device=grouper
ro.product.board=grouper
ro.product.manufacturer=asus
ro.product.locale.region=US
ro.build.id=JRN84D
ro.build.display.id=JRN84D
But this does not make any difference...
Does anybody have better settings for the build.prop that fully enable the play store?
Kind regards,
Algem.
104 Guest(s)
Devices in use: Desktop (88), Phone (16)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
