2013/02/26
New Chinese rom based on V2.0. from ondabbs.
Download link.
This doesn't look like an official firmware to me, is it ?
2013/02/26
This doesn't look like an official firmware to me, is it ?Cheers.
I don't think it is.Looks like a custom of the official V2.0.
Brush: If you use the OTA upgrade program updates, guaranteed to be the official Recovery If you are using third-party Recovery, please enter the recovery upgrade, otherwise it will cause infinite loop in the boot animation. The upgrade will format the data partition, your own backup. The built-in card, you can create a preinstall directory, you need to install the program on the inside, the boot can be automatically installed for the first time.
Last paragraph copied translation from site.
2013/02/26
kaotikjezta said
Someone walk me through doing this and getting it back to English please.
Download update to pc,on tablet turn on usb debugging ,plug usb in to pc and tablet,send file to tablet,on tablet go to update (blue arrow) select local update select 2.0.1 .system should update then reboot. go to settings,press speech bubble on left,touch top right then scroll down for English.if you don't have toolbox download rom toolbox from play store install and go to build prop,select persist.sys.language and change to en,at the same time you can change persist.sys.timezone to i.e. Europe/London. and persist.sys.country to i.e GB.
Before using toolbox goto settings,security,permissions and activate s.u. so you have root.
The following users say thank you to groundhogman for this useful post:
kaotikjeztaMost Users Ever Online: 803
Currently Online: jfdc
51 Guest(s)
Devices in use: Desktop (45), Phone (7)
Dante1975
adb
amanita12
mony18
spiik
nikitamaan
