2013/04/09
Procedure tested onda V972 v 3.0 and v 3.2_v1 on Android 4.2.2
To enable multi-user IT TAKES:
- Install "ES File Explorer"
- Open "ES File Explorer"
- Select Tools Root Explorer
- Select Mount R/W
- Select the permissions R/W on /system
- Now open the file /system/bulid.prop
- Go into edit mode
- Append at this file   fw.max_users=4
Note: Make sure the bottom of the file there is a blank line
- Save the change.
- Reconfigure permissions R/W for /system
- Reboot system
Now in then settings on tablet will find the menu when you can enable other users
when creating the user, the tablet performs a partial Rebbot, and on the startup screen appear the various users enabled.
note: might be interesting to have this setting already on the rom arctablet
83 Guest(s)
Devices in use: Desktop (77), Phone (6)
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
